Miscellaneous Utility Plugin icon Miscellaneous Utility Plugin — ARC utilities: DataQuery for SQL/ODBC/OLEDB/Excel with parameterized queries returning array variables; Ticks/Millis timing functions. Try it →
Not yet but im happy to help. Do you have a link for some information to this robot you want to hack or mod? Pics and specs are appreciated.:)
Hello rbot993 thanks for a quick response. This kit is a plexi topper add on to the famous (and common) tamiya tank tracks kit. I will grab the tutorial videos and make a list of ez robot products in the video. First to interface the gearbox motors w ezb you need a H Bridge. The l298n Hbridge supports 2.5 amps current draw which is plenty for your Brutus base.
Ez board
Sonar ping sensor
L298n 2.5 amp H Bridge motor controller
Standard servo for radar movement
( if you want video navigation , spy capabilities or color and facial tracking you need ez cam as well)
Videos
Introduction to your ez board
https://synthiam.com/Community/Videos/Default.aspx?id=5eAfzOra7iI
Use a gamepad to control Brutus
https://synthiam.com/Community/Videos/Default.aspx?id=4b59UOPfHfQ
Give your tamiya brutus object detection radar and avoidance
https://synthiam.com/Community/Videos/Default.aspx?id=XneX8EIL_qk
Give your Brutus color tracking https://synthiam.com/Community/Videos/Default.aspx?id=-5BItTLDdGU
Connecting your ezb for the first time
https://synthiam.com/Community/Videos/Default.aspx?id=K5zhYdEucdU
If you get the ez cam and a second servo you can have color / motion tracking https://synthiam.com/Community/Videos/Default.aspx?id=5oElzgr50K8
Just a fun inspirational video of omnibot driving around looking at things and seeing his reactions. Entertainment if nothing else:)
https://synthiam.com/Community/Videos/Default.aspx?id=NvaCJKKCYFQ
These videos should answer some of your questions and also give you ideas of ways you can use your brutus base. Have fun and I look forward to you posting your ideas and progress of your project. Its much easier to help if we see what your doing.:) - Josh S
You are welcome. Be sure start a thread for your robots build under the projects section so you recieve help and we can see your progress. Have fun! - Josh
