i wanted to make an ini pose,a pose kd will pose when i connect to ARC.
dont know whits one to take.
The Navigator
— Path-planning navigator using ARC NMS position and obstacle data to map, log trajectories, and autonomously follow waypoints.
In your connection or ini script you can call an Auto Position frame...
If you use the above example you will need a frame called "KDstand" in your Auto Position control. You don't have to use the name KDstand, you can call it whatever you want as long as there is a corresponding frame named after it...
or you can do it the hard way.... You can set KD's servos one by one...
rr
ok i make a frame how i want che will stand.
thanks
Good, you create the frame... What did you call it?
Have a look at the JD example, it does exactly what you are asking.
rr kd stand.and che waves say hi am kd. i have to adjust the rgb in head seems not right. then i post a video.
rich
ah thank you
