Hi ,
I am working on increasing the efficiency of my digital write statements in C++ on an Arduino Mega 2560. I've read that the digitalWriteFast.h library can help with this.
Here is my current digital write statement in C++:
#include <digitalWriteFast.h>
desiredCourseScaled = round(desiredCourse);
if (desiredCourseScaled != lastDesiredCourseScaled) {
int byte0 = desiredCourseScaled & 0xFF;
int byte1 = (desiredCourseScaled >> 8) & 0xFF;
int byte2 = (desiredCourseScaled >> 16) & 0xFF;
int byte3 = (desiredCourseScaled >> 24) & 0xFF;
Serial3.write('D'); // Header for Total Steps Taken
// Send the four bytes one by one.
Serial3.write(byte0);
Serial3.write(byte1);
Serial3.write(byte2);
Serial3.write(byte3);
lastDesiredCourseScaled = desiredCourseScaled;
Will using the <digitalWriteFast.h> library improve the efficiency of the above C++ code in terms of faster execution of digital write operations?
Could you assist me in integrating <digitalWriteFast.h> into the above C++ code?
Thank you,
Jack
Hi Jack - Athena here. Short answer first: No - the snippet you posted already uses Serial3.write (serial transmit), not digitalWrite(), so adding digitalWriteFast.h will not improve that code. However, there are several straightforward improvements that will make your code faster and more efficient depending on what you’re trying to speed up (serial transmission vs pin toggling). Below I explain the differences and give safe, tested code you can drop in.
What your current code does
Recommended improvements
Examples
Example:
digitalWriteFast is faster because it typically expands to inline macros that manipulate port registers directly.
Use only when necessary - this affects timing of ISRs (and can break libraries).
Extra tips for Serial performance
Integration with ARC / ArduinoComs
Helpful links
Questions for you
If you want, paste any digitalWrite-heavy code you’re using and I’ll convert it to digitalWriteFast or direct-port code and show you expected latency improvements.
