Auto Position (Gait) icon Auto Position (Gait) — Create servo frames and actions to animate gaits and gestures with automatic motion planning, software ramping, movement panel, import/export Try it →
Resolved Resolved by Jeremie!
I2c Information Update?
DJ, Anybody,
Is there new information about I2C? The last reference I can find is: https://synthiam.com/Community/Questions/322
I am trying to write a script that will have the EZ-B v4 respond as an I2C slave to a master I2C device. To do this, the master device sends the EZ-B data, the EZ-b is then able to respond by sending data to the master.
The script fails and the WiFi connection is broken. I have to power down, then reconnect the EZ-B.
Here is a script snippet: (The address of the master is 0x4)
The master is in a loop I2C writing a '1', then I2C reading << :loop $V1 = I2CRead(0,0x4,1) Print ("V1 = "+$V1) I2CWrite(0,0x4,40) #decimal 40 is the value I want written sleep(1000) goto(loop)
Thank you.
You are unable to "read" unless there is a request sent.
Attempting to read i2c will pause forever (as you are experiencing) without knowing there is data. Do something like this...
  1. Send a request for data
  2. Read the known data size that has been requested
For more information, look at the i2c BlinkM example...
# Shift the bits over
# Set the LSB (first bit) to a 1
# When first bit is a 1 on i2c, that means
# it is a Read Address
$i2cAddress = 0x09
Print("BlinkM Address: " +  $i2cAddress)
# Tell BlinkM we want the RGB Values
i2cWrite(0, $i2cAddress, 0x67)
# Receive the RGB Values
$raw = i2cRead(0, AUTO, $i2cAddress , 3)
# Print the number of bytes
Print("Received: " + Length($Raw) + " Bytes")
# Print the hex value of each byte
PrintHex($Raw)
# Split the array of bytes and assign to each variable
$Red = GetByte($Raw[0])
$Green = GetByte($Raw[1])
$Blue = GetByte($Raw[2])
DJ,
Thanks for the quick reply.
Your script is setting the EZ-b as the master and the BlinkM as the slave. I need the EZ-b to be the slave.
The EZ-B is unable to be a slave - it's configured as a master by factory.
I am trying to use the EZ-b as a 'capability enhancer' for robots built with the Lego EV3. To do this the EV3 uses a Dexter Industries I2C sensor block. This block sets the EV3 as the I2C master.
I have connected the EV3 via an arduino and got it to work with the information in https://www.dexterindustries.com/howto/connecting-ev3-arduino/
Near the end is a section headed "EV3 as the Master".
BTW- https://synthiam.com/Community/Questions/6532 shows the robot that I wish to 'enhance' with all the super EZ-B capabilities. A video is at: https://www.youtube.com/watch?v=DiGyeV759JE
Again, thanks.
Hi @OldbotBuilder,
You could essentially run your robot with 2 masters. The ez-bv4 can communicate serially to the Arduino. You could write a program on the Arduino that could translate your serial data from the ez-b and create I2C commands to send to the EV3 controller, probably wouldn't be that efficient but it's an idea.
Otherwise, I would suggest to try interfacing the motors and sensors from the EV3 directly to the ez-b. I believe LEGO peripherals also communicate as I2C slaves, but I don't have enough info on these new LEGO kits to confirm that.
From what I read, it looks like the EV3 can only be a Master (no slave option) and the EZB as DJ said likewise is designed to only be a Master.
My thoughts are you would either need to use an Arduino in between the two. Or it might be possible to communicate with the LEGO EV3 over wifi using TCP/IP. This might work.
Jeremie and JustinRatliff,
Good ideas and I will look into both suggestions. Thanks to you both.
Now - how does the 'resolved by' credit get assigned?
