j
— Edited
6 Participants
EZB Connections
— Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices.
Where there is a will there is a way I "can" connect as many to one computer as the computer can handle
I think
But I will not say how as I only have 3 EZ-B's so fare and have not been able to test it fully but the tests I did looked promising
It might be possible by connecting each EZ-B to the same network then opening enough ARC windows since each one can connect to 5 per project.
I don't think anyone has ever tried this yet but it would definitely be an interesting test
It would also be unnecessarily time consuming
You can run many different copies of ARC at the same time on the same computer as long as they are in different folders.
I had up to 10 running a few weeks ago for a little test ..... wish I had more than just 3 EZ-B's lol
