Key Control icon Key Control — Assign scripts to any keyboard key (press/release), map arrow keys to movement controls; activates when the control has focus (green). Try it →
Hugging Face Model Not Supported
I have a question about the ARC "Hugging Face" Robot Skill.
I set up the API as instructed. I'm using a USB webcam (connected directly to the PC running ARC) and enabled "face" and "motion" tracking. I tried the first example from the Hugging Face Skill documentation, but all I get is this error:
enabled.","type":"invalid_request_error","param":"model","code":"model_not_supported"}}
20:55:27 Error: HTTP 400 from Hugging Face. {"error":{"message":"The requested model 'Qwen/Qwen2.5-VL-7B-Instruct' is not supported by any provider you have enabled.","type":"invalid_request_error","param":"model","code":"model_not_supported"}}
What am I missing?
Camera Device by Synthiam
Use PC or robot cameras for vision tracking: color, QR, glyph, face, object, motion; record video/data, control servos and movement, run scripts
Hugging Face by Hugging Face Inc
Connects your robot camera to Hugging Face AI models for vision chat, object tracking, classification, captioning, and autonomous movement.
That error is coming from Hugging Face’s provider routing, not from ARC itself.
What it means
Qwen/Qwen2.5-VL-7B-Instruct is a vision-language model, and Hugging Face is saying:
"You don’t currently have any enabled provider that can serve this model."
So ARC is successfully sending the request, but Hugging Face is rejecting the model because your account/token/provider setup doesn’t have access to a backend that can run it.
What to check
1) Verify the model supports the task you chose
In the Hugging Face skill configuration, make sure you’re using the correct task:
  • Vision Chat for asking the model to see and respond
  • Object Detection for finding faces/objects in the image
  • Image Classification for labeling the whole image
  • Image Captioning for describing the scene
If you enabled face and motion tracking, that sounds more like Object Detection, not Vision Chat.
2) Try a known-good default model for the selected task
In the skill’s kebab/gear menu configuration, switch to Default for that task and test again.
For example:
  • Object Detection: facebook/detr-resnet-50
  • Image Captioning: Salesforce/blip-image-captioning-large
These are generally easier to get working than a large vision-chat model.
3) Check Hugging Face model access / provider availability
That specific error usually means one of these:
  • Your token is valid, but the model is not available on the enabled provider
  • The model may require a different provider than the one currently enabled in your Hugging Face account
  • You may need to select a different model that is supported by serverless inference
Hugging Face has a support article for model-based robot use in ARC here:
Important note about your webcam
Your USB webcam on the PC is fine. ARC can use that with the Camera Device skill. The webcam is not the issue here.
Make sure you have:
  1. Camera Device skill added
  2. Webcam selected in that skill
  3. Camera skill started
  4. Hugging Face skill configured to use that camera feed
If the camera is not running, Hugging Face would usually complain about no active camera, not model support.
Best next step
Try this:
  1. Open the Hugging Face skill settings
  2. Switch to Object Detection
  3. Use the default detection model
  4. Press Save
  5. Run Query Now
If that works, then the issue is specifically the Qwen vision-chat model/provider combo.
If you want Vision Chat
If your goal is the "robot sees and talks" behavior, you may need to:
  • choose a different vision model that your enabled provider supports, or
  • use a Hugging Face Inference Endpoint / compatible provider that supports that model
Quick question
Are you trying to do:
  • face detection / tracking, or
  • vision chat where the model describes the scene and answers questions?
If you tell me which task mode you selected in the skill, I can point you to the exact model/settings to use in ARC.
image.png The image above shows my settings, This is the default setting according to the provided info about this skill. As shown I see a HTTP 400 error showing up, which I am guessing is an issue with connecting to the Huggyface site?
Thanks for the screenshot - that helps.
What I see is that you’re on Vision Chat with the default Qwen/Qwen2.5-VL-7B-Instruct model, and ARC is successfully reaching Hugging Face. So this is not a webcam problem and not a general "can’t connect to Hugging Face" problem.
What the error means
The key part is:
model_not_supported
That means:
  • ARC is sending the request correctly
  • Hugging Face received it
  • Hugging Face does not have an enabled provider on your account/session that can run that model
So the issue is model/provider availability, not ARC connectivity.
Why the default model can fail
Even if the skill documentation lists a default model, Hugging Face serverless inference may not currently serve that model for your account/provider setup. Model availability can change, and some models require:
  • a different provider
  • an inference endpoint
  • accepted model terms
  • or a smaller/more common vision model
What to try next
1) Test with a simpler model
In the Hugging Face skill:
  • open the kebab/gear menu
  • go to the Hugging Face tab
  • change the model to something more commonly supported
If you want to test Vision Chat, try another vision model that is known to work with your provider setup.
If you want to test face/motion tracking, that should usually be done with Object Detection, not Vision Chat.
2) Make sure you selected the right task
From your description, you mentioned face and motion tracking. That sounds like:
  • Object Detection mode for detecting a face/person
  • then Camera Tracking to move servos
For that, the default object detection model is a much better test than Qwen vision chat.
3) If you want the exact default docs behavior
The docs may assume a provider setup that isn’t available in every Hugging Face account. If the default model doesn’t run, the fix is usually to pick a different supported model, not to change ARC networking.
In short
This is not a connection failure to Hugging Face.
It is Hugging Face saying:
"I received your request, but I can’t run that model with any provider currently enabled for your account."
Try this in ARC:
  1. Switch the Hugging Face skill to Object Detection
  2. Leave the model at the default detection model
  3. Make sure your Camera Device skill is started
  4. Press Query Now
If that works, then your ARC setup and webcam are fine, and the issue is only the Vision Chat model choice.
Helpful reference
If you want, I can help you pick a working Vision Chat model or walk you through setting up object/face tracking correctly in ARC step by step.
Yes, I would like some help on picking a working vision chat model since I have no idea on what to look for or setup. This is my first time doing this.
Absolutely - for a first-time setup, the safest path is to use a smaller, commonly supported vision model rather than the big default one.
What to look for
In Hugging Face Vision Chat mode, you want a model that:
  • supports vision-language / image-to-text / image-text-to-text
  • is available through the provider enabled on your Hugging Face account
  • is not a huge model that requires special access or an inference endpoint
The default Qwen/Qwen2.5-VL-7B-Instruct is a good example of a modern model, but it may not be available through your current provider setup, which is why you got the model_not_supported error.
Good first models to try
Try one of these in ARC one at a time:
  • HuggingFaceTB/SmolVLM-2B-Instruct
  • HuggingFaceTB/SmolVLM-Instruct
  • microsoft/Phi-3.5-vision-instruct
  • llava-hf/llava-1.5-7b-hf
If one fails with provider/model support, try the next one.
My recommendation for a beginner
Start with:
It’s smaller and often easier to get working than larger vision models.
How to change it in ARC
  1. Open the Hugging Face robot skill.
  2. Press the kebab/gear menu for the skill settings.
  3. Go to the Hugging Face tab.
  4. Leave Task set to Vision Chat.
  5. Replace the model name with one of the models above.
  6. Press Save.
  7. Press Query Now.
If it works, you should see a response in the log and $HfSpeak / $HfResponse should populate.
If it still errors
If you get another model_not_supported error, that means the selected model is still not available from your enabled Hugging Face provider.
In that case, the quickest way forward is:
  • try the next model in the list above
  • or use Object Detection mode first, which is much more likely to work out of the box for tracking a face/person
Important note about your goal
You mentioned face and motion tracking. For that, you may actually want:
  • Track label: person
  • Pan/Tilt servos assigned on the Camera Tracking tab
That is the correct setup if you want the camera to follow a person’s face/body. Vision Chat is better for "look at the camera and describe what you see."
Helpful ARC docs
Quick question
Do you want your robot to:
  1. talk about what it sees with Vision Chat, or
  2. track a person’s face with the camera?
If you tell me which one, I can give you the exact ARC settings to use next.
Not successful. I have tried all four of the models you recommended, none of them worked. I have tried different tracking settings in the camera,face or motion, or object. Again nothing is working.
Each time., I still get this message....
 20:38:08 Error: Attempting to read GetCurrentBitmapManaged while locked.
20:39:02 Error: Attempting to read GetCurrentBitmapManaged while locked.
20:39:42 Error: HTTP 400 from Hugging Face. {"error":{"message":"The requested model 'microsoft/Phi-3.5-vision-instruct' is not supported by any provider you have enabled.","type":"invalid\_request\_error","param":"model","code":"model\_not\_supported"}}
20:40:17 Error: Attempting to read GetCurrentBitmapManaged while locked.
20:41:00 Error: Attempting to read GetCurrentBitmapManaged while locked.
While I created the API thru the HuggyFace website, are there other settings on the website I need to set/choose, thats not mentioned in the original information of this skill?
Yes - there are two separate issues in your log, and the Hugging Face website setup is likely part of one of them.
1) model_not_supported = Hugging Face provider issue
This one is still the same root problem:
The requested model ... is not supported by any provider you have enabled.
That means your token is valid enough for ARC to reach Hugging Face, but your Hugging Face account is not enabled for a provider that can serve that model.
What to check on Hugging Face
Please log into Hugging Face and check:
  • Settings Access Tokens
    • Confirm the token is correct and not expired
  • Any billing / provider / inference settings
    • Some models require a provider that isn’t enabled by default
  • Model page access
    • Some models are gated and need you to accept terms on the model’s page
The exact wording in the error is the giveaway: this is not ARC failing to connect; it’s Hugging Face rejecting the model because no enabled backend can run it.
2) Attempting to read GetCurrentBitmapManaged while locked
This is a separate ARC camera-image contention problem.
It usually means more than one skill is trying to read the camera frame at the same time, or the camera feed is being accessed while another process is holding the bitmap.
Common causes
  • Camera Device is open in one skill, while Hugging Face is also trying to pull frames
  • Another vision skill is active at the same time
  • The camera stream is paused/starting/stopping repeatedly
  • Tracking is enabled in multiple places at once
What to do
Try this clean test setup:
  1. New empty project
  2. Add Camera Device
  3. Select your USB webcam
  4. Press Start on Camera Device
  5. Add Hugging Face
  6. In Hugging Face, use only one mode at a time:
    • either Vision Chat
    • or Object Detection
    • not multiple tracking modes in the Camera skill while testing
  7. Press Query Now
Also make sure no other robot skills are trying to use the camera.
Important: for face tracking, don’t use Vision Chat
If your goal is to track a face/person, use:
  • Camera Device for the webcam
  • Hugging Face Object Detection
  • target label: person
  • then use Camera Tracking tab for pan/tilt servos if you have them
That is much more reliable than trying to use Vision Chat for tracking.
Most likely answer to your question
No, there usually isn’t a special hidden setting on Hugging Face that ARC forgot to mention. The big issue is:
  • the model/provider combination you’re trying is not enabled on Hugging Face, and
  • ARC is also seeing a camera frame lock conflict
Next best step
Please try this exact diagnostic:
Clean camera test
  • Create a brand-new ARC project
  • Add only Camera Device
  • Start the webcam
Then add Hugging Face
  • Use Object Detection
  • Try the default model
  • Do not enable other camera/vision skills
If that works, then we know the camera lock issue was caused by another skill or setup.
If you want, I can help you with either of these next:
  1. a known-good ARC camera + Hugging Face test setup
  2. a face-tracking setup using the Camera Device skill with pan/tilt
  3. checking your Hugging Face token / provider settings step-by-step
If you’d like, send a screenshot of:
  • the Hugging Face skill settings
  • the Camera Device skill
  • and your Hugging Face token/settings page with sensitive info hidden
and I’ll help you narrow it down.
Yes, I would like a step by step of these three items......
