ZAMA Emotion Model icon ZAMA Emotion Model — Valence-arousal emotion engine generating persistent, configurable robot moods and event-driven emotional outputs for expressive behaviors. Try it →
How to move a servo 360 using blocky with time
How To Move A Servo 360 Using Blocky With Time
I would like to control a 360-degree continuous rotation servo using Blockly in Synthiam ARC, specifying the duration of movement instead of a specific angle. Which blocks should I use to achieve this? I assume I need to use the "Move Servo" block to identify the servo number. What other blocks should I use to set the duration and speed for the servo's movement? Should I also consider using the "Move Forward" block, which allows setting left speed, right speed, and duration in milliseconds?
Continuous Servo by Synthiam
Control a 3-wire continuous 360-degree servo in ARC: adjustable forward/reverse speeds, start/stop buttons, board/port selection and test controls
That's great to hear! Thanks for the kind words. Let me know what your next step with the kids is if you need any help:)
