I would like to use an arduino uno r3 board that i have for a robot project and want to use ARC to drive servos and such. How would i do this?
jdptwh
How Do I Control An Arduino Uno R3 From Arc?
Arduino Genuino Uno
by Arduino
USB
Servos
12
UART
ADC
6
Digital
14
Okay that’s good - the arduino connected at 57600 matched between both devices. Good start
ensuring the tx and rx are connected correctly is also mandatory. If you’re unsure of the pinouts, find a reliable source to check. The tx must be connected to rx. The rx must be connected to tx. I sound like a broken record but it’s absolutely imperative
lastly, you cannot power the Arduino off usb with the connection to the esp32. If you power it off usb, you will be using the built in serial for debugging and not ARC connection through the esp32
