Is it possible to control a hexapod using EZ-Script or movement script in the ARC built for non-programmers?
techcrab101
— Edited
Servo Speed
— Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved.
You bet. There are a few options. I'd suggest using the movement scriPt control.
The most time consuming part will be creating the positions of each servo in scripts.
thanks
