Personality Forge icon Personality Forge — Adds a Personality Forge chatbot to ARC, giving memory, emotions, AIScript dialogue, persistent conversation IDs and speech/chat integration via API. Try it →
Help! Http Server Help!
Hello Everybody,
Im working on a project for school that envolves the use of the HTTP server. When I got the kit everything was working, but then I took it to school and tried to make it work there and it didn't. Now that I am back home and start the HTTP server....I go on my tablet to login, using the default "admin", and nothing shows up...However, when I go on my computer where the EZ-B v3 is connected it works fine..... PLEASE ANYONE HELP!
Thanks again! :D
Do you have anything else running which uses port 80? HTTP server for something else, teamviewer etc? You can change the port in the settings if that's the case.
A video is better than words:)
To access it just pop in your IP address followed by : then the port number. i.e. 192.168.0.100:81
Thanks, it is working now, for some reason the port 80, is in use by something else but I did not know it..... I was fustrated, Thanks again Rich :)
don't forget to port forward whichever port you chose to the correct PC on your router settings. If you don't have a fixed IP using a DDNS service is also a great help.
Uh oh! If 80 is used by something else, that could mean a virus. Surprising, the ARC software checks if the port is used when enabling the http server. It will return an error if the port is in use.
