Sorry but I believe I found what I'm looking for. I was unable to delete post, only edit it.
blush Herr
Dual Hbridge
— Two-channel Dual H-Bridge movement panel to control two DC motors (on/off) for forward, reverse, left, right via EZ-B digital ports; no PWM speed.
blush Herr
Check in the setting, under scripts there are scripts to run on detection of each of the glyphs.
So basically, if it detects Glyph 1 it will run the script set in settings for Glyph 1. This script can be anything.
In your case, I assume it would just need to be;
or
And you found that before I finished replying... it's here for future users to find though
Thanks Rich
I didn't really see anything on the Glyphs in the manual but looked closer at the QR codes and put 2 and 2 together and there it was
