Roll Pitch Yaw icon Roll Pitch Yaw — Rotate and position camera or object with roll/pitch/yaw controls; save camera settings; bind or monitor a 3-value EZ-Script array for live rotation. Try it →
Found Fairly Cheap Way To Cut Plastics
so that it wont melt and give a good clean cut i just bought a NO MELT plastic cutting saw blade for $90 for my table saw they make in all sizes and for hand circular saw another way is to get a wet saw and add very cold water or attach a small compressor out of a refrigerator,like i did for my work what make plastics melt it the blade gets hot and melts the plastic i did some some repair on whats called a plastic chiller machine ,at plastic making factory if you do use a wet saw you need to change the blade for a fine tooth blade and most are about 4 inch plus needs to be stainless steel ,so no rust another trick to get water cold is use ice cubes
but using a special NO MELT CUTTING blade for plastics you dont need the WET SAW i am building a very good robot machine shop with every machine neededi ordered many machines,lathe,mill and a lot lot more
Fred,
Sounds like it is going to be a Fun place to be.
Mel
nowwaiting on the EZB to drop down in price,so far i see its about $140 plus shipping and i need 5 or more so thats $700,makershed had a good price at $99 but so far no stock,so will just wait and wait ,not in a hurry machine shop cost me over $2000 my christmas gift to my self
I've been told that Makershed will not have them at that price ever again. It was a one time buy or something like that of the older model EZ-B.
Go for the 20% off sale, it's probably the best deal your going to get.
maybe,i can wait still not in a rush,most likely get is in usa,shipping high in canada the 3 i bought from makershed was the lastest version of EZB wasent a older model i check no 20 % off sale its over ,shipping is over $18 to usa
