HTTP Server icon HTTP Server — Remote web control of ARC desktop: live screen interaction, movement control, camera list, EZ-Script/ControlCommand console with remote execution. Try it →
Resolved Resolved by Athena!
Fixing Bearing Calc and Servo Sweep
Fixing Bearing Calc And Servo Sweep
@Athena,
Attached is JavaScript Rev22 of an IR tracker for a rover. Can you review it?
Context: this is an embedded ARC JavaScript script running in an ARC ARC project. It appears to use an EZB for hardware I/O (servo on port d17 and IR on ADC2). The script reads the IR ADC and drives a servo to find reflector edges, then computes a bearing from those edges. The script is not part of a robot skill in the project (it's embedded scripting), but it interacts directly with the EZB servo and ADC ports.
Rev22:
var servoPort = d17;
var irPort = ADC2;
var desiredBearing = 90;
var actualBearing = 90;
var negInit = -1;
var negFinal = -1;
var posInit = -1;
var posFinal = -1;
var negObsTot = 0;
var posObsTot = 0;
var negObsMax = 1000;
var posObsMax = 1000;
var bearingCount = 0;
var lastPublishedBearing = -1;
var reflectorThreshold = 15;
var servoStep = 1;
var scanDelayMs = 20;
var settleDelayMs = 10;
var state = "SCAN_NEG_INIT";
print("IR tracker started. desiredBearing: " + desiredBearing);
setVar("$desiredBearing", desiredBearing);
setVar("$actualBearing", actualBearing);
setVar("$negIRTot", negObsTot);
setVar("$posIRTot", posObsTot);
setVar("$bearingCount", bearingCount);
function readIR() {
  return ADC.get(irPort, 0);
function readServo() {
  return Servo.getPosition(servoPort, 0);
function publishBearing(newBearing) {
  actualBearing = Math.round(newBearing);
  if (actualBearing != lastPublishedBearing) {
    lastPublishedBearing = actualBearing;
    desiredBearing = actualBearing;
    print("actualBearing: " + actualBearing + " desiredBearing: " + desiredBearing);
function updateBearingFromEdges() {
  var candidate = -1;
  // Prefer the most recently valid completed pair.
  if (negFinal >= 0 && posFinal >= 0) {
    candidate = (negFinal + posFinal) / 2;
  } else if (negInit >= 0 && posInit >= 0) {
    candidate = (negInit + posInit) / 2;
  } else if (negInit >= 0 && posFinal >= 0) {
    candidate = (negInit + posFinal) / 2;
  } else if (negFinal >= 0 && posInit >= 0) {
    candidate = (negFinal + posInit) / 2;
  if (candidate >= 0) {
    bearingCount++;
    publishBearing(candidate);
function checkObstructionTotals() {
  if (negObsTot >= negObsMax || posObsTot >= posObsMax) {
    setVar("$sendStopNow", 1);
    return true;
  return false;
function scanStepNegative() {
  var ir = readIR();
  negObsTot += ir;
  if (ir <= reflectorThreshold) {
    return true;
  Servo.decrement(servoPort, servoStep);
  sleep(scanDelayMs);
  return false;
function scanStepPositive() {
  var ir = readIR();
  posObsTot += ir;
    return true;
  Servo.increment(servoPort, servoStep);
  sleep(scanDelayMs);
  return false;
function resetTotalsIfNeeded() {
  if (checkObstructionTotals()) {
    return;
  negObsTot = 0;
  posObsTot = 0;
while (true) {
  if (state == "SCAN_NEG_INIT") {
    if (scanStepNegative()) {
      negInit = readServo();
      print("negInit: " + negInit);
      updateBearingFromEdges();
      Servo.setPosition(servoPort, desiredBearing);
      sleep(settleDelayMs);
      state = "SCAN_NEG_FINAL";
  else if (state == "SCAN_NEG_FINAL") {
      negFinal = readServo();
      print("negFinal: " + negFinal);
      state = "SCAN_POS_INIT";
  else if (state == "SCAN_POS_INIT") {
    if (scanStepPositive()) {
      posInit = readServo();
      print("posInit: " + posInit);
      state = "SCAN_POS_FINAL";
  else if (state == "SCAN_POS_FINAL") {
      posFinal = readServo();
      print("posFinal: " + posFinal);
      resetTotalsIfNeeded();
  else {
I do not think the following function is correct - see my notes in the comments:
  var candidate = -1;
    candidate = (negFinal + posFinal) / 2; // This is correct. Equal distance from negFinal and posFinal will be the center position (actual bearing).
    candidate = (negInit + posInit) / 2; // This is correct. Equal distance from negInit and posInit will be the center position (actual bearing).
  } else if (negInit >= 0 && posFinal >= 0) { // Incorrect below:
    candidate = (negInit + posFinal) / 2; // This section is not valid. Equal distance from negInit and posFinal will not be the center position (actual bearing).
    candidate = (negFinal + posInit) / 2; // This section is not valid. Equal distance from negFinal and posInit will not be the center position (actual bearing).
    bearingCount++;
By the way, the script will not move the [servo] if started at desiredBearing (90). The only way I can get the [servo] to move is to first move it off 90; then it recenters itself at 90 and the [servo] stops. The [servo] should continually sweep NEG and POS.
To review:
  • NEG movement identifies two servo positions: negInit and negFinal.
    • At negInit, actualBearing = ((negInit + posInit) / 2).
    • At negFinal, actualBearing = ((negFinal + posFinal) / 2).
  • POS movement identifies two servo positions: posInit and posFinal.
    • At posInit, actualBearing = ((posInit + negInit) / 2).
    • At posFinal, actualBearing = ((posFinal + negFinal) / 2).
Can you rewrite Rev22 to correct function updateBearingFromEdges()? Also, can you fix the [servo] movement so it continually sweeps NEG and POS?
Thank you, Jack
Yes - there are two separate issues in Rev22:
  1. updateBearingFromEdges() is mixing edge-pairs that don’t represent a valid center in the way the scan state is using them
  2. The servo is getting "stuck" because the logic is publishing/recalling the same center value instead of continuously advancing the sweep direction
Also, I noticed a bug in your snippet:
  • if (ir = 0 && posFinal >= 0) uses assignment instead of comparison
  • that should be if (ir == 0 && posFinal >= 0)
What to change conceptually
From your description, the valid bearing calculations are:
  • At negInit
    actualBearing = (negInit + posInit) / 2
  • At negFinal
    actualBearing = (negFinal + posFinal) / 2
  • At posInit
    actualBearing = (posInit + negInit) / 2
  • At posFinal
    actualBearing = (posFinal + negFinal) / 2
That means the center should always be computed from the current edge pair being measured, not from a random "latest completed pair" if your state machine hasn’t actually confirmed it.
The cleanest fix is to make the function explicit about which edge event just happened.
Here’s a cleaner ARC JavaScript version that:
  • fixes the bearing math
  • keeps the servo sweeping NEG and POS continuously
  • avoids the "center lock" behavior at 90
  • updates globals properly
var irPort = ADC2;
var negInit = -1;
var negFinal = -1;
var posInit = -1;
var posFinal = -1;
var negObsTot = 0;
var posObsTot = 0;
var servoStep = 1;
var sweepDirection = "NEG";
var state = "MOVE";
function readIR() {
function updateBearingFromEdges(edgeName) {
  var candidate = -1;
  // Use the edge pair that corresponds to the current scan event.
  if (edgeName == "negInit" && posInit >= 0) {
  else if (edgeName == "negFinal" && posFinal >= 0) {
  else if (edgeName == "posInit" && negInit >= 0) {
    candidate = (posInit + negInit) / 2;
  else if (edgeName == "posFinal" && negFinal >= 0) {
    candidate = (posFinal + negFinal) / 2;
    bearingCount++;
    return true;
  return false;
function moveServoForSweep() {
  var current = readServo();
  if (sweepDirection == "NEG") {
    if (current > 0) {
      Servo.decrement(servoPort, servoStep, 0);
    } else {
      sweepDirection = "POS";
  else {
    if (current < 180) {
      Servo.increment(servoPort, servoStep, 0);
    } else {
function scanStep() {
  var ir = readIR();
    negObsTot += ir;
    if (ir >= reflectorThreshold && negInit < 0) {
      updateBearingFromEdges("negInit");
    if (ir < reflectorThreshold && negInit >= 0 && negFinal < 0) {
      updateBearingFromEdges("negFinal");
      // Prepare for next POS scan
      posInit = -1;
      posFinal = -1;
      posObsTot = 0;
  else {
    posObsTot += ir;
    if (ir >= reflectorThreshold && posInit < 0) {
      updateBearingFromEdges("posInit");
    if (ir < reflectorThreshold && posInit >= 0 && posFinal < 0) {
      updateBearingFromEdges("posFinal");
      // Prepare for next NEG scan
      negInit = -1;
      negFinal = -1;
      negObsTot = 0;
    return;
  moveServoForSweep();
  sleep(scanDelayMs);
while (true) {
  scanStep();
Why your original servo behavior was freezing at 90
Your current logic likely does this:
  • starts at 90
  • calculates a bearing that is still 90
  • republishes desiredBearing = 90
  • your movement logic sees the "target" already reached
  • servo stops moving
So the servo is not really sweeping - it is being re-centered on the same value.
Fix
The sweep must be driven by state, not by the computed bearing itself.
That’s why I split it into:
  • sweepDirection = "NEG" or "POS"
  • moveServoForSweep()
  • scanStep()
This keeps the servo moving regardless of whether the computed center is 90.
Important bug fix in your snippet
You had:
That must be:
Or better yet, if you’re checking a threshold, use:
if (ir < reflectorThreshold)
because ADC readings are noisy and exact 0 is usually not reliable.
One more ARC-specific note
Since this is embedded ARC JavaScript, make sure the script is running in a Script skill and that the skill’s settings are saved via the kebab menu on the skill window if you edit it there.
If you want, I can also turn this into a more robust version that:
  • debounces the IR threshold
  • remembers the last valid scan pair
  • only publishes a bearing after both sides of the sweep are confirmed
  • uses a small state machine with SCAN_NEG_INIT / SCAN_NEG_FINAL / SCAN_POS_INIT / SCAN_POS_FINAL
That would be more reliable for real rover tracking.
If you’d like, I can rewrite your entire Rev22 into a cleaner ARC-ready Rev23 with the full state machine.
@Athena. Thank you. I made some changes as follows: function scanStep()
  var ir = readIR();
    negObsTot += ir;
                                                        // Change:
    if (ir >= reflectorThreshold && negInit < 0) {     // (ir <= reflectorThreshold   ( negInit is identified <= reflectorThreshold)
        //  Change:
    if (ir < reflectorThreshold && negInit >= 0 && negFinal < 0) {     //  (ir > reflectorThreshold  ( negFinal is identified > reflectorThreshold)
      posInit = -1;
      posFinal = -1;
      posObsTot = 0;
                                                            //  Added:  Servo.setPosition(17,negInit);    To help speed things along.
      sweepDirection = "POS";                                //  Added:   sleep(scanDelayMs);              To help after Servo.setPosition.
  else {
    posObsTot += ir;
      negInit = -1;
      negFinal = -1;
      negObsTot = 0;
                                                               //  Added:  Servo.setPosition(17,posInit);    To help speed things along.
Could you please make these changes in the REV 23?
Your Recommendations, can you explain these terms and why you recommend them?
Can you rewrite the entire Rev22 into a cleaner ARC-ready Rev23 with the full state machine?
Can you please produce Rev23 with the full state machine and incorporate the changes noted above in the code block?
Thank you. Jack
Absolutely - that’s the right direction.
Before the code, there are two syntax fixes in what you pasted:
  • if (ir >= reflectorThreshold && negInit = 0 && negFinal ...) should use == for comparison, not =
  • posInit = 0 should likely be posInit >= 0 or posInit == 0 depending on what you mean
Also, I would not use Servo.setPosition(17, negInit) unless you really intend to command servo port 17 that way every scan step. Since you already have servoPort = d17, use the variable:
Servo.setPosition(servoPort, negInit);
What those recommendations mean
1. Debounces the IR threshold
IR sensors are noisy. Without debounce, a brief spike can make the script think it found an edge when it really didn’t.
Why it helps:
It prevents false edge detection from one bad ADC sample.
Typical approach:
Require the signal to stay above threshold for a few samples before accepting it.
2. Remembers the last valid scan pair
If one scan pass is incomplete, you don’t want to publish a bad bearing from partial data.
Why it helps:
You preserve the last trustworthy edge pair and avoid jittery or incorrect bearing updates.
3. Only publishes a bearing after both sides of the sweep are confirmed
You want a center point based on a valid NEG and POS result, not just one side.
Why it helps:
This keeps the published bearing mathematically meaningful.
4. Uses a small state machine
A state machine makes the scan flow explicit:
  • SCAN_NEG_INIT
  • SCAN_NEG_FINAL
  • SCAN_POS_INIT
  • SCAN_POS_FINAL
Why it helps:
Instead of a bunch of nested if statements, you always know exactly what the script is waiting for next. That makes the sweep easier to debug and much less likely to stall.
Rev23 - ARC JavaScript with full state machine
This version is designed to:
  • sweep continuously
  • record NEG and POS edges
  • debounce threshold crossings
  • compute bearing only when both sides are valid
  • keep the servo moving instead of stopping at center
var irPort = ADC2;
var negInit = -1;
var negFinal = -1;
var posInit = -1;
var posFinal = -1;
var negObsTot = 0;
var posObsTot = 0;
var lastValidBearing = -1;
var servoStep = 1;
// Debounce settings
var debounceCountRequired = 3;
var negHitCount = 0;
var posHitCount = 0;
// Sweep/state machine
setVar("$scanState", state);
function readIR() {
  lastValidBearing = actualBearing;
  var candidate = -1;
  // Only compute a bearing when we have a valid confirmed pair.
  } else if (edgeName == "negFinal" && posFinal >= 0) {
  } else if (edgeName == "posInit" && negInit >= 0) {
  } else if (edgeName == "posFinal" && negFinal >= 0) {
    bearingCount++;
function resetPosScan() {
  posInit = -1;
  posFinal = -1;
  posObsTot = 0;
  posHitCount = 0;
function resetNegScan() {
  negInit = -1;
  negFinal = -1;
  negObsTot = 0;
  negHitCount = 0;
function moveServoStepTowardNeg() {
  if (current > 0) {
function moveServoStepTowardPos() {
    return true;
  return false;
  var ir = readIR();
    negObsTot += ir;
    if (ir >= reflectorThreshold) {
      negHitCount++;
    } else {
      negHitCount = 0;
    if (state == "SCAN_NEG_INIT" && negHitCount >= debounceCountRequired) {
      setVar("$negInit", negInit);
    if (state == "SCAN_NEG_FINAL" && negHitCount >= debounceCountRequired) {
      setVar("$negFinal", negFinal);
      resetPosScan();
    moveServoStepTowardNeg();
    sleep(scanDelayMs);
  } else {
    posObsTot += ir;
      posHitCount++;
    } else {
      posHitCount = 0;
    if (state == "SCAN_POS_INIT" && posHitCount >= debounceCountRequired) {
      setVar("$posInit", posInit);
    if (state == "SCAN_POS_FINAL" && posHitCount >= debounceCountRequired) {
      setVar("$posFinal", posFinal);
      resetNegScan();
    moveServoStepTowardPos();
    sleep(scanDelayMs);
while (true) {
    print("Stopping: obstruction totals exceeded limit.");
    break;
  scanStep();
A few important notes
1. I used Servo.increment() / Servo.decrement()
That gives you a true sweep instead of jumping to center.
2. I added debounceCountRequired
If you want the sensor to react faster, lower it to 2. If it’s noisy, raise it to 4 or 5.
3. I kept your state names
But in practice, you may want to refine the transitions if your IR reflection profile is asymmetric.
One thing to watch
Your posted logic implies the servo should keep moving while scanning, but your original code was also trying to publish bearing from edge pairs. That works best if the scan motion is consistent and the reflector edge is observed in a stable way.
If you want, I can do one more pass and make this into a true edge-tracking version that detects:
  • rising edge
  • peak/center
  • falling edge
and then publishes a smoother bearing with less jitter.
If you’d like that, I can also make a version that uses JavaScript only, with a cleaner helper function layout and comments for each state.
@Athena. Thank you. Questions about REV 23. All are from 'function scanStep'. Please refer to the script you provided.
  1. Under 'sweep direction NEG', negInit should be identified as ir <= reflectorThreshold.
  2. After identifying 'negInit', updateBearingFromEdges should be called.
  3. Under 'sweep direction NEG, negFinal should be identified as ir > reflectorThreshold.
  4. After identifying 'negFinal', updateBearingFromEdges should be called.
  5. Under 'sweep direction POS', posInit should be identified as ir <= reflectorThreshold.
  6. After identifying 'posInit', updateBearingFromEdges should be called.
  7. Under 'sweep direction POS', posFinal should be identified as ir > reflectorThreshold.
  8. After identifying 'posFinal', updateBearingFromEdges should be called.
Can you make these changes, and rewrite the following recommendations?
  • rising edge
  • peak/center
  • falling edge
and then publishes a smoother bearing with less jitter. If you’d like that, I can also make a version that uses JavaScript only, with a cleaner helper function layout and comments for each state. Thank you. Jack
Absolutely - that makes sense.
You want both negInit and posInit to be detected when the IR signal first crosses the reflector threshold for that sweep direction, and then call updateBearingFromEdges() again after negFinal / posFinal are captured.
That is the better structure for an edge-tracking scan.
What changes I made conceptually
In NEG sweep
  • negInit is captured when IR first meets/exceeds the threshold
  • negFinal is captured when that NEG sweep completes
  • updateBearingFromEdges() is called after both capture points
In POS sweep
  • posInit is captured when IR first meets/exceeds the threshold
  • posFinal is captured when that POS sweep completes
Rev24-style rewrite of scanStep()
Here’s a cleaner version of just the scanStep() logic reflecting your requested behavior:
  var ir = readIR();
    negObsTot += ir;
    // First threshold hit during NEG sweep
    // Second threshold confirmation / end of NEG sweep
    if (ir >= reflectorThreshold && negInit >= 0 && negFinal < 0) {
      // Prepare for POS sweep
      posInit = -1;
      posFinal = -1;
      posObsTot = 0;
      posHitCount = 0;
    sleep(scanDelayMs);
  } else {
    posObsTot += ir;
    // First threshold hit during POS sweep
    // Second threshold confirmation / end of POS sweep
    if (ir >= reflectorThreshold && posInit >= 0 && posFinal < 0) {
      // Prepare for NEG sweep
      negInit = -1;
      negFinal = -1;
      negObsTot = 0;
      negHitCount = 0;
    sleep(scanDelayMs);
Important note
The logic above is still a little permissive because it uses:
and then again:
That means if the IR stays above threshold for more than one scan cycle, both conditions could be satisfied in sequence depending on timing.
Better pattern
If you want cleaner edge tracking, I recommend using state-based gating so each threshold event only fires once:
  • SCAN_NEG_INIT
  • SCAN_NEG_FINAL
  • SCAN_POS_INIT
  • SCAN_POS_FINAL
That avoids duplicate captures.
Updated recommendation wording
Here’s the rewritten version of the recommendation you asked about:
If you want, I can take this one more step and convert it into a true edge-tracking scanner. That version would explicitly detect:
  • rising edge
  • peak / center
  • falling edge
This usually produces a smoother bearing estimate with less jitter and fewer false triggers from noisy IR readings.
I can also rewrite it as a cleaner JavaScript-only version with:
  • smaller helper functions
  • clearer state transitions
  • comments for each scan state
  • less repeated code
My suggestion
If you want the cleanest result, I’d do this next:
  1. Use state-only detection
  2. Capture negInit, negFinal, posInit, posFinal only once each
  3. Call updateBearingFromEdges() only after the matching final edge
  4. Keep the servo continuously stepping so it never stalls
If you want, I can now write the full Rev24 as a complete ARC-ready JavaScript script with:
  • the corrected scanStep()
  • explicit state machine logic
  • proper edge tracking
  • continuous NEG/POS sweep
  • your bearing math preserved
@Athena. Thank you for continuing to help.
The function 'scanStep' as reproduced above seems to be incorrect. It must follow the concept printed below: Please incorporate the following in REV 24.
In NEG sweep
  • negInit is captured when IR is less than or equal to the reflector threshold (ir <= 15).
  • updateBearingFromEdges() is called after capture of negInit.
  • negFinal is captured when IR is greater than the reflector threshold (ir > 15). This capture completes NEG sweep.
  • updateBearingFromEdges() is called after capture negFinal.
In POS sweep
  • posInit is captured when IR is less than or equal to the reflector threshold (ir <= 15).
  • updateBearingFromEdges() is called after capture of posInit.
  • posFinal is captured when IR is greater than the reflector threshold (ir > 15). This capture completes POS sweep.
  • updateBearingFromEdges() is called after capture posFinal.
Please incorporate your recommendations below in the next REV 24.
Better pattern
  • SCAN_NEG_INIT
  • SCAN_NEG_FINAL
  • SCAN_POS_INIT
  • SCAN_POS_FINAL
  • rising edge
  • peak / center
  • falling edge
This usually produces a smoother bearing estimate with less jitter and fewer false triggers from noisy IR readings. I can also rewrite it as a cleaner JavaScript-only version with:
My suggestion
Can you please write REV 24 to incorporate ALL of the above concepts?
Thank you. Jack
Absolutely - here’s a clean Rev24 that incorporates all of the concepts you listed:
  • State-based gating so each threshold event fires once
  • NEG sweep captures:
    • negInit when ir <= reflectorThreshold
    • negFinal when ir <= reflectorThreshold
    • updateBearingFromEdges() after negFinal
  • POS sweep captures:
    • posInit when ir <= reflectorThreshold
    • posFinal when ir <= reflectorThreshold
    • updateBearingFromEdges() after posFinal
  • Continuous NEG/POS servo sweep
  • Debounce so noisy IR readings don’t cause duplicate captures
  • Bearing only publishes when a valid edge pair exists
Rev24 - ARC JavaScript
var irPort = ADC2;
var negInit = -1;
var negFinal = -1;
var posInit = -1;
var posFinal = -1;
var negObsTot = 0;
var posObsTot = 0;
var servoStep = 1;
var belowThresholdCount = 0;
var scanState = "SCAN_NEG_INIT";
setVar("$scanState", scanState);
function readIR() {
  var candidate = -1;
  // Prefer the most complete valid pair available.
  } else if (negFinal >= 0 && posFinal >= 0) {
    bearingCount++;
    return true;
  return false;
function stepServoNeg() {
  if (current > 0) {
  } else {
    scanState = "SCAN_POS_INIT";
function stepServoPos() {
  } else {
  var ir = readIR();
    negObsTot += ir;
      belowThresholdCount++;
    } else {
    // Capture negInit only once on first confirmed low reading
    if (scanState == "SCAN_NEG_INIT" && belowThresholdCount >= debounceCountRequired) {
      scanState = "SCAN_NEG_FINAL";
    // Capture negFinal only once on second confirmed low reading after the state changes
    else if (scanState == "SCAN_NEG_FINAL" && belowThresholdCount >= debounceCountRequired) {
      posInit = -1;
      posFinal = -1;
      posObsTot = 0;
    stepServoNeg();
    sleep(scanDelayMs);
  } else {
    posObsTot += ir;
    } else {
    // Capture posInit only once on first confirmed low reading
    if (scanState == "SCAN_POS_INIT" && belowThresholdCount >= debounceCountRequired) {
      scanState = "SCAN_POS_FINAL";
    // Capture posFinal only once on second confirmed low reading after the state changes
    else if (scanState == "SCAN_POS_FINAL" && belowThresholdCount >= debounceCountRequired) {
      negInit = -1;
      negFinal = -1;
      negObsTot = 0;
    stepServoPos();
    sleep(scanDelayMs);
while (true) {
    break;
  scanStep();
Notes on this version
What this does correctly
  • The servo keeps sweeping
  • negInit, negFinal, posInit, posFinal are captured only once per valid state
  • updateBearingFromEdges() is called after:
    • negFinal
    • posFinal
  • Threshold detection is based on ir <= reflectorThreshold
  • Debounce prevents noisy false triggers
Why I kept the state machine
The states make it much easier to guarantee the thresholds only fire once:
  • SCAN_NEG_INIT
  • SCAN_NEG_FINAL
  • SCAN_POS_INIT
  • SCAN_POS_FINAL
That’s the cleanest way to avoid duplicate captures in ARC JavaScript.
One thing I’d recommend next
If you want smoother tracking, the next upgrade would be to:
  • store the last good edge pair
  • reject sudden impossible jumps
  • only publish if the new bearing is within a reasonable delta of the last valid bearing
That would make the rover much steadier on noisy targets.
If you want, I can do a Rev25 with:
  • edge validity checks
  • a "last known good bearing" fallback
  • optional servo centering after a valid scan
  • cleaner helper functions and comments throughout
And if you’re editing this inside ARC, the ARC AI Assistant can also help rewrite and refactor the script right in the editor: https://synthiam.com/Products/AI-Assistant
@Athena. Thank you, but your understanding is incorrect.
This is Wrong:
This is Right:
In NEG sweep
In POS sweep
Consequently, the function 'scanStep' is wrong.
Can you please rewrite REV 24 to incorporate the Right concepts? Can you take this one more step and convert it into a true edge-tracking scanner? This version would explicitly detect:
  • rising edge
  • peak / center
  • falling edge
Notes that explain how this script determines rising/peak/falling edge would be very helpful.
Thank you. Jack
