Serial Terminal icon Serial Terminal — PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex Try it →
@Merne.... The resistor would connect the ground to one of the sensor leads and the other sensor lead connects directly to the ezb signal pin of an analog port... just like the diagram you have in post# 7...
I'm using a pressure/force sensor called a Softpot Rotary Potentiometer in the arm of my B9. It works great.
This sensor should not be operated without placing a 10k resistor in line on either the hot or ground power feed. If a resistor is not used then the pot will burn a hole in it's self if you press down across small gap at the bottom of the SoftPot with your finger or anything else. When you do this you're bypassing the internal resistance and shorting V+ to GND. By putting a 10K resistor in line like I mentioned above this will keep the fault current very low if you bridge the gap and keep a hole from burning through it. This method will also give you almost 95% of the applied voltage all the way to the end of the rails. I've used both 3.3 and 5 vdc with this sensor. Both voltages worked nicely but I seemed to get better response useing 5v. However that could of been just my application. They are rated to handle 1 Watt max so you don't really have to worry about overloading it with the way we use these.
Now if you find your reading is floating to much and cant get a positive reading when touched then you should also put a resister (10K) between the ground pin and the output pin.
