UBTECH Alpha Servos UBT-12HC icon UBTECH Alpha Servos UBT-12HC — Control UBTECH Alpha UBT-12HC smart servos via ARC using EZ-B v4/IoTiny UART, assign virtual ports, set baud, custom bits and position mapping. Try it →
Fehlermeldung: Error in response received: Server was unable to process request.
Fehlermeldung: Error In Response Received: Server Was Unable To Process Request.
ich bekomme seit kurzem folgende Fehlermeldung: "Sending data (88046 Bytes) Data Sent! Error in response received: Server was unable to process request. ---> One or more errors occurred. ---> One or more errors occurred. ---> SendRequest: Non-success status received :: Status Code: NotFound; Reason: Not Found; Content: "404 Not Found" Kann mir jemand helfen?
JD Humanoid by EZ-Robot
@DJ Sures, @Synthiam Support, THANK YOU VERY MUCH for the super fast support. The Bing Speech Recognition is working perfectly again. @Athena, please translate into English. Best regards from Germany!
Germany
Gelöst! - nochmals vielen Dank.
