The Navigator icon The Navigator — Path-planning navigator using ARC NMS position and obstacle data to map, log trajectories, and autonomously follow waypoints. Try it →
Yes, I have seen that also but I would rather suppport DJ and his efforts rather than China. I do appreciate your tip and if DJ says it will be awhile I will probably go with your suggestion.
We're releasing a case with a fan. It will be ready with the launch of EZ-Bits, in about 2 weeks. This Canada Customs mess has rattled us; we're a little behind on everything.
Hello, DJ. In your film Robot Voltage Regulator Fan it is shown, how you connect power supplies to the system block through tiny digital ampere-volt-meter. Tell please how it is called and where he can be bought? Regards, SergeyZN
Bump...on easy bits....anyone......beuller...beuller...
