Ultrasonic Distance icon Ultrasonic Distance — Displays HC-SR04 ultrasonic distance readings in ARC; scriptable via GetPing(), pausable, sets a variable with multiplier, optional NMS output Try it →
Netherlands
Ez-Script Modular File Write Question
hi all, i was just wondering a thing.
(example) you have the following code:
read file if file exists : create a variable for each row with data empty file modify variables for each data row if needed write file else: write file with default values
i know this is possible wih ez-script, but is it also possible with a given amount of rows, without modifying the code? if so, how? :s
note: this might be usefull for when adding things to robot projects which save data to files, and in the end, it will save time coding if it is modular code.:)
The only truly dumb question is the one not asked :)
