Lidar-Lite Laser Module icon Lidar-Lite Laser Module — Laser Lidar-Lite ARC control reads distance, velocity and signal strength (0-40m+) via EZ-B v4 i2c, setting EZ-Script vars for robotics Try it →
If you look at the EZ-B, they are labeled. They are hard to see because they are between the case and the pins on the board.
you are correct. This image is wrong with what is screen printed on the board.
Thanks. I was really confused.
DBEARD
good find.
changed allreddy
