Waveshare Bus Servos icon Waveshare Bus Servos — Control Waveshare servos (TTL/RS485): set position & speed, release torque, read position. RTS option for converters; reverse-engineered protocol. Try it →
If you look at the EZ-B, they are labeled. They are hard to see because they are between the case and the pins on the board.
you are correct. This image is wrong with what is screen printed on the board.
Thanks. I was really confused.
DBEARD
good find.
changed allreddy
