Sphero Movement Panel icon Sphero Movement Panel — Control Sphero via Bluetooth in ARC. Detects two COM ports (one connects); requires deleting and re-pairing after disconnects or reboots. Try it →
Resolved Resolved by Robot Doc!
Ez-B V4 Not Connecting?
I'm trying to get my ez-b working. I connect to the wifi source made by the ez-b. Windows states its a limited network. When I try to connect to the webserver via ARC it says your not connected to a network in the browser. Any help? I've reseted the wifi chip and rebooted and still. I'm running windows 8.1 with the latest ARC .
Thanks Technopro, I just fired up my Win 8.1 laptop/touch screen to see if it would give me trouble connecting to my EZB4 but with WiFi enabled and Airplane mode turned off it connects just fine. Glad to read you basically fixed it yourself. That seems to be a small problem with closing an open ticket. You can't close it with your own name even if you came up with the solution.
