MPU6050 Accelerometer Gyro Temperature icon MPU6050 Accelerometer Gyro Temperature — Reads MPU6050 gyro, accelerometer and temperature via I2C, initializes and returns data on-demand to EZ-Script variables using ControlCommand RunOnce Try it →
This may be a dumb suggestion, but check the polarity of the wiring. Also, make sure the board is not sitting on anything conductive.
All sorted now, after getting my multi-meter out, it was a bad connection on the battery pack.
Thanks.
I had the same issue with my battery pack. The terminals are too short to make a good connection with the batteries. What did you wind up doing? I just went out and bought a new battery pack from my local hardware store.
I just put a blob of solder on the positive connection pads and that did it.
On the older battery packs I found that a few of them after hard use would break connection where the red wire meets the battery pack. You can prevent this from happening with a little dab of hot glue for a little extra support.
Hello All-
I had the same problem. I put new batteries into the battery holder and plugged it into the EZ-B. Nothing...
Then I noticed that the batteries were not in contact with the +(positive) contact in the battery box. The springs weren't strong enough to push the battery up to make contact. I guess the plastic holder "grabs onto" the batteries just a tad too much.
I ended up just sliding the batteries up manually to make contact, and it worked.
In the image, you can see how the + side of the battery is not touching the contact.
Brad
