Hola
Hopefully this is easy. Can the standard EZ servos (builders kit) safely run at 5 volts (but plenty of amps)?
Thanks,
- Scott
Read Digital
— Read TTL digital input from an ARC I/O port; real-time red/green status for low (0V) or high (+3.3/5V), selectable board/port and read interval.
Hola
Thanks,
Yep over 4.8V is fine.
And you'll find the specifications for the servo on all product pages that use the servos. Here's a direct link to the product that you're inquiring about. Scroll down and you will find the servo specifications: https://synthiam.com/Shop/AccessoriesDetails.aspx?prevCat=101&productNumber=2
