Conversational Menu— Voice menu tree to navigate options and run scripts on ARC robots. Multi-level, customizable prompts, speech I/O, timeout and repeat/back.Try it →
You need an editor like MakerWare. Unless you want to print them on a 3D printer through EZ-Robots. What are you trying to do? ARC opens ARC Program files named *.ezb.
Look across the top of that dialogue, it has a path to where the STL files should be, this is where you need to put the STL files if you don't want to browse through the hard drive to find them (the column on the left, double click the .. in it to go up a directory and browse through your hard drive).
The default location is usually Documents\EZ-Builder\My STL Files
my 2 cents.
hi i just wanted to see how it looks.i dont have an printer or makerware.
thank you moviemaker
sorry forgot
you don't need any other programs, ARC can view STL files just fine.
You are opening it incorrectly though...
there's nothing in there.
thank you guys
i found it.i had to schare the stl folder ,too let it chown in ARC.
thank you moviemaker and rich
rich where do you get nieks part?found it.
