Ultrasonic Radar icon Ultrasonic Radar — Ultrasonic on a servo sweeps 180°; radar shows distances and obstacles, integrates with movement panels for automatic avoidance, scriptable GetPing Try it →
An earlier version of the file saved on ezcloud loaded without issues. Please find below a the actual file that failed to load: ez.EZB
I too had that error window once but disapeared after reloading an exact saveas file I always keep. Try a reboot and or go back to a saved file....or a prior version(right click your file and open prior version tab!)
Thanks, I tried reloading 3 exact save as files but still get same error. When I right click the file I don't see the prior version tab, could this be because I am using a windows 8 tablet?
right click, properties, previous versions.
Generally this isn't switched on and no previous versions are saved.
Scrub that, just read you said Windows 8. It's not in properties on Windows 8
Thanks DJ, it loaded fine, but without the script manager. I updated to your most recent update and the original file worked again. I deeply appreciate your support and great work!
