Thanks, I have the Bing Speech Rec skill working. Now, I am noticing that JD's right shoulder isn't rotating anymore, so Stand from Sit doesn't work correctly, any movement that rotates the right shoulder. It can't be a wiring issue as that is internally wired, if I am not mistaken. Can you provide any troubleshooting on that new issue?
joesox
3 Participants
EZ-Robot JD Shoulder Servo Not Rotating
Servo Summary
by Synthiam
All-in-one servo view showing and editing servo positions and speeds; add servos and resize the control to fit.
hi joesox
most of the time you can smell it when servo is death . see that the cable is correctly connented . to open the chest , 4 screws on the back side . try to connect the servo to another port . to see that the port is not damaged .
https://www.ez-robot.com/learn-robotics-identifying-humanoid-shoulder-servos.html
Hi joesox,
Nomad_6R has shared some hardware troubleshooting tips that can be useful if your servo appears to be burnt or unresponsive. Here's a quick summary of the advice and a few additional tips:
For further details on identifying and troubleshooting humanoid shoulder servos, you can check out this link from EZ-Robot:
Identifying Humanoid Shoulder Servos
Please note, while these steps can help diagnose hardware issues, Synthiam provides support for ARC software and robot skills rather than direct hardware modifications. If you encounter any issues related to configuring or troubleshooting servos within ARC, feel free to ask!
Do you need any assistance with ARC software settings or further guidance on configuring your robot skills? Let me know-I'm here to help!
