Hitachi-LG LDS Lidar icon Hitachi-LG LDS Lidar — Hitachi-LG LDS 360-degree LiDAR driver streaming scans into ARC NMS for obstacle detection, SLAM use, Arduino hookup, config options and variables. Try it →
Roli is only 2 wheeled drive so unless you use omni type wheels (or two more motors) 4 regular rubber tires won't work... Roli was designed to use tank treads...
ah thanks RR two motors more means also Hbridge more. are there better motors to get,these makes a lot of sound,little speed.
No, you don't need another H-bridge... You just parallel the wires for 2 motors on one side and 2 motors on the other side... Just one H-bridge
you mean just the pos+ and the negati - conected from the motors on the hbridge. so i have then 4 wires each side.
will that give more speed and sound ?
thanks for helping
are there any motors to get that are much quiter ? and are the original motors with plastik gears or metal ones. has any one a good link.
