Sketch Pad icon Sketch Pad — Script-driven Sketch Pad for ARC: draw shapes, text, lines and faces via controlCommand() to visualize object locations, paths and robot data. Try it →
You only need to ask once, it will be answered when someone with the answer sees it.
Wall-E U Command is 20.3 x 27.9 x 34.9 cm according to Amazon.
thats what he used though? seems small. by the way asked over periods of 2 days
The Real Wall-E uses the Wall-E U Command. The Wall-E U Command dimensions are 20.3 x 27.9 x 34.9 cm. What size were you expecting? That is plenty of space for the EZB, servos, camera, sensors & batteries you just need to get a touch creative.
