What are the dimensions of dj's Wall-e? trying to build a replica. need to know the size. L-W-H
— Edited
DHT11 Temp & Humidity Sensor
— Read DHT11 temperature and humidity on Arduino (signal pin 4) using EZ-Genuino_DTH11_Uno firmware; exposes $Temp and $Humid variables.
You only need to ask once, it will be answered when someone with the answer sees it.
Wall-E U Command is 20.3 x 27.9 x 34.9 cm according to Amazon.
thats what he used though? seems small. by the way asked over periods of 2 days
The Real Wall-E uses the Wall-E U Command. The Wall-E U Command dimensions are 20.3 x 27.9 x 34.9 cm. What size were you expecting? That is plenty of space for the EZB, servos, camera, sensors & batteries you just need to get a touch creative.
i found this wall-e on ebay. Don't think it was a u-command but it's darn close. It should work u think? cgi.ebay.ca/ws/eBayISAPI.dll?VISuperSize&item=230918082988
