EZB Connection icon EZB Connection — Connects EZ-B I/O controllers to ARC via COM or IP (5 connections). Supports init scripts, battery monitoring, TCP/EZ-Script server and serial/I2C. Try it →
You can buy these on ebay. I did this before I discovered ubec's and built a distribution board. This keeps you from having to cut wires. I know you can pass 7.4 and bring it down to 5v with the ones I bought. I want to say that the will bring up to 20ish v down to 5v.
Been a while since I spec ' ed them out. I personally think the ubec and distribution panel is a better option but that is just me.
https://synthiam.com/Community/Questions/6140
Input voltage is probably much higher than the EZB4 max voltage so I wouldn't worry about maxing it out (probably around 30V)....
I think i will go the distribution panel route.
Will make my life way easier.
Thanks
