Serial Terminal icon Serial Terminal — PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex Try it →
Crashing While Using Ar Drone (1.0) Camera In ARC
Hey. Thanks for a great program, but i need some help.
I can control my AR DRONE 1.0 from the ARC. BUT, when i add camera controller component in the program it takes about 15-30 seconds, then the program crashes with the following error reports:
OS: Windows 8 64bit
- System
  - Provider
   [ Name]  Application Error
  - EventID 1000
   [ Qualifiers]  0
   Level 2
   Task 100
   Keywords 0x80000000000000
  - TimeCreated
   [ SystemTime]  2014-11-24T20:14:22.000000000Z
   EventRecordID 15106
   Channel Application
   Computer Zoulburner
   Security
- EventData
   ARC.exe
   2014.11.18.0
   546b9f48
   gdiplus.dll
   6.3.9600.17415
   54503bef
   c0000005
   000e9d85
   1bd0
   01d00822b25a65f7
   C:\Program Files (x86)\EZ-Robot Inc\EZ-Builder\EZ-Builder.exe
   C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.9600.17415_none_dad8722c5bcc2d8f\gdiplus.dll
   79e47332-7416-11e4-8312-50e549c467c1
This event is not displayed correctly because the underlying XML is not well formed. Below is the raw text of the event.
1026200x8000000000000015105ApplicationZoulburnerApplication: ARC.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.AccessViolationException Stack: at System.Drawing.SafeNativeMethods+Gdip.GdipDrawImageI(System.Runtime.InteropServices.HandleRef, System.Runtime.InteropServices.HandleRef, Int32, Int32) at System.Drawing.Graphics.DrawImage(System.Drawing.Image, Int32, Int32) at EZ_B.Camera.(System.Object) at System.Threading.ThreadHelper.ThreadStart_Context(System.Object) at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object) at System.Threading.ThreadHelper.ThreadStart(System.Object)
Anyone know what to do? Best regards. Fredrik Sweden
  1. Are you using the latest ARC?
  2. Do you see any of the camera video before the error?
  3. Can you please use the Diagnostic Report and paste the response here? Diagnostic report can be found under Add Control -> General -> Diagnostic Report
  4. Have you performed the usual Microsoft Windows debugging procedures? Such as uninstall application, reboot, install application?:)
Hello, Thanks for the fast reply.
  1. Yes i am using the latest one.
2)I see the camera from the drone like 15-30 seconds. And if i use a webcamera it doesnt crash at all.
3
uTorrent
Adblock Plus for IE
Archeage
ASIO4ALL
BankID sakerhetsprogram
Battlefield 3
Battlefield 4
Battlefield Heroes
Battlelog Web Plugins
CanoScan Toolbox Ver4.9
CL-Eye Driver
Cyberduck 4.6 (15810)
D3DX10
D-Link AirPremier AP Manager for DWL-3200AP
EZ-Builder
Fotogalleriet
Glyph
GRID
GRID Autosport
Guild Wars 2
ImgBurn
LPT System Updater Service
Microsoft ASP.NET MVC 4 Runtime
Microsoft SQL Server 2005 Compact Edition [ENU]
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161
Microsoft Visual C++ 2010  x86 Redistributable - 10.0.40219
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.60610
Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.60610
Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.60610
Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.60610
Movie Maker
MSVCRT
MSVCRT110
MyMaptuner
Native Instruments Massive
Native Instruments Service Center
NVIDIA PhysX
OpenAL
Origin
Phoenix R/C trademark
Photo Common
Photo Gallery
PunkBuster Services
Rocksmith 2014
Samsung Magician
Sony Mobile Update Engine
Sony PC Companion 2.10.235
Spotify
Steam
TeamSpeak 3 Client
TeamViewer 9
Uplay
Windows Live Communications Platform
Windows Live Essentials
Windows Live Installer
Windows Live Photo Common
Windows Live PIMT Platform
Windows Live SOXE
Windows Live SOXE Definitions
Windows Live UX Platform
Windows Live UX Platform Language Pack
Virtual DJ Pro Full - Atomix Productions
Ping 192.168.1.1 replied Success took 2
Description: TP-LINK 150Mbps Wireless N Adapter
Status: Up
Receive Only: False
DHCP: True
Auto Private Addressing Active: False
Auto Private Addressing Enabled: True
MTU: 1500
DHCP Server: 192.168.1.1
Win32_NetworkAdapter
AdapterType = Ethernet 802.3
AdapterTypeId = 0
Availability = 3
Caption = [00000000] TP-LINK 150Mbps Wireless N Adapter
ConfigManagerErrorCode = 0
ConfigManagerUserConfig = False
CreationClassName = Win32_NetworkAdapter
Description = TP-LINK 150Mbps Wireless N Adapter
DeviceID = 0
GUID = {8707EE00-25BB-44A3-9D16-39E26D652456}
Index = 0
Installed = True
InterfaceIndex = 3
MACAddress = xxxxxxxx
Manufacturer = Qualcomm Atheros Communications Inc.
MaxNumberControlled = 0
Name = TP-LINK 150Mbps Wireless N Adapter
NetConnectionID = Wi-Fi
NetConnectionStatus = 2
NetEnabled = True
PhysicalAdapter = True
PNPDeviceID = PCI\VEN_168C&DEV_002D&SUBSYS_0301168C&REV_01\4&340CE6FE&0&30A4
PowerManagementSupported = False
ProductName = TP-LINK 150Mbps Wireless N Adapter
ServiceName = athr
Speed = 54000000
SystemCreationClassName = Win32_ComputerSystem
SystemName = ZOULBURNER
TimeOfLastReset = 20141124130236.489165+060
Microsoft Kernel Debug Network Adapter
Availability = 3
Caption = [00000001] Microsoft Kernel Debug Network Adapter
Description = Microsoft Kernel Debug Network Adapter
DeviceID = 1
Index = 1
Installed = True
InterfaceIndex = 2
Manufacturer = Microsoft
Name = Microsoft Kernel Debug Network Adapter
PhysicalAdapter = False
PNPDeviceID = ROOT\KDNIC\0000
ProductName = Microsoft Kernel Debug Network Adapter
ServiceName = kdnic
Realtek PCIe GBE Family Controller
Availability = 3
Caption = [00000002] Realtek PCIe GBE Family Controller
ConfigManagerErrorCode = 22
Description = Realtek PCIe GBE Family Controller
DeviceID = 2
GUID = {0FEEE74F-E22A-4F2A-8605-19F9702E42A9}
Index = 2
Installed = True
InterfaceIndex = 4
Manufacturer = Realtek
Name = Realtek PCIe GBE Family Controller
NetConnectionID = Ethernet
NetConnectionStatus = 0
NetEnabled = False
PNPDeviceID = PCI\VEN_10EC&DEV_8168&SUBSYS_E0001458&REV_06\4&33588FB7&0&0048
ProductName = Realtek PCIe GBE Family Controller
ServiceName = RTL8168
Microsoft Wi-Fi Direct Virtual Adapter
Availability = 3
Caption = [00000003] Microsoft Wi-Fi Direct Virtual Adapter
Description = Microsoft Wi-Fi Direct Virtual Adapter
DeviceID = 3
Index = 3
Installed = True
InterfaceIndex = 5
Name = Microsoft Wi-Fi Direct Virtual Adapter
PNPDeviceID = {5D624F94-8850-40C3-A3FA-A4FD2080BAF3}\VWIFIMP_WFD\5&72B66D9&0&01
ProductName = Microsoft Wi-Fi Direct Virtual Adapter
ServiceName = vwifimp
Microsoft ISATAP Adapter
Availability = 3
Caption = [00000004] Microsoft ISATAP Adapter
Description = Microsoft ISATAP Adapter
DeviceID = 4
Index = 4
Installed = True
InterfaceIndex = 6
Name = Microsoft ISATAP Adapter
ProductName = Microsoft ISATAP Adapter
Teredo Tunneling Pseudo-Interface
AdapterType = Tunnel
AdapterTypeId = 15
Availability = 3
Caption = [00000005] Microsoft Teredo Tunneling Adapter
Description = Microsoft Teredo Tunneling Adapter
DeviceID = 5
Index = 5
Installed = True
InterfaceIndex = 7
Name = Teredo Tunneling Pseudo-Interface
PNPDeviceID = SWD\IP_TUNNEL_VBUS\TEREDO_TUNNEL_DEVICE
ProductName = Microsoft Teredo Tunneling Adapter
ServiceName = tunnel
Speed = 100000
Microsoft ISATAP Adapter #2
AdapterTypeId = 15
Availability = 3
Caption = [00000006] Microsoft ISATAP Adapter
DeviceID = 6
Index = 6
Installed = True
InterfaceIndex = 8
Name = Microsoft ISATAP Adapter #2
PNPDeviceID = SWD\IP_TUNNEL_VBUS\ISATAP_1
Speed = 100000
Availability = 3
Caption = [00000007] Microsoft ISATAP Adapter
DeviceID = 7
Index = 7
Installed = True
InterfaceIndex = 9
Microsoft 6to4 Adapter
Availability = 3
Caption = [00000008] Microsoft 6to4 Adapter
Description = Microsoft 6to4 Adapter
DeviceID = 8
Index = 8
Installed = True
InterfaceIndex = 10
Name = Microsoft 6to4 Adapter
ProductName = Microsoft 6to4 Adapter
Win32_NetworkAdapterConfiguration
\\ZOULBURNER\root\cimv2:Win32_NetworkAdapterConfiguration.Index=0
DatabasePath = %SystemRoot%\System32\drivers\etc
DefaultIPGateway = 192.168.1.1
DHCPEnabled = True
DHCPLeaseExpires = 20141125110946.000000+060
DHCPLeaseObtained = 20141125104946.000000+060
DHCPServer = 192.168.1.1
DNSDomainSuffixSearchOrder =
DNSEnabledForWINSResolution = False
DNSHostName = Zoulburner
DomainDNSRegistrationEnabled = False
FullDNSRegistrationEnabled = True
GatewayCostMetric = 0
Index = 0
InterfaceIndex = 3
IPAddress = 192.168.1.2 fe80::d842:dff9:ee16:db95
IPConnectionMetric = 25
IPEnabled = True
IPFilterSecurityEnabled = False
IPSecPermitIPProtocols =
IPSecPermitTCPPorts =
IPSecPermitUDPPorts =
IPSubnet = 255.255.255.0 64
ServiceName = athr
SettingID = {8707EE00-25BB-44A3-9D16-39E26D652456}
TcpipNetbiosOptions = 0
WINSEnableLMHostsLookup = True
\\ZOULBURNER\root\cimv2:Win32_NetworkAdapterConfiguration.Index=1
DHCPEnabled = True
Index = 1
InterfaceIndex = 2
IPEnabled = False
ServiceName = kdnic
SettingID = {8718928D-CBEB-45EA-A621-800A9249001D}
\\ZOULBURNER\root\cimv2:Win32_NetworkAdapterConfiguration.Index=2
DHCPEnabled = True
Index = 2
InterfaceIndex = 4
IPEnabled = False
SettingID = {0FEEE74F-E22A-4F2A-8605-19F9702E42A9}
\\ZOULBURNER\root\cimv2:Win32_NetworkAdapterConfiguration.Index=3
DHCPEnabled = True
Index = 3
InterfaceIndex = 5
IPEnabled = False
SettingID = {7C5268BA-1E9B-431A-9B40-AA4B73F43C3C}
\\ZOULBURNER\root\cimv2:Win32_NetworkAdapterConfiguration.Index=4
DHCPEnabled = False
Index = 4
InterfaceIndex = 6
IPEnabled = False
SettingID = {68FCEBE9-F843-4F9A-83FF-E367E08B6081}
\\ZOULBURNER\root\cimv2:Win32_NetworkAdapterConfiguration.Index=5
DHCPEnabled = False
Index = 5
InterfaceIndex = 7
IPEnabled = False
SettingID = {49CF090E-CB7C-4A36-B3C2-3C2A3C106D41}
\\ZOULBURNER\root\cimv2:Win32_NetworkAdapterConfiguration.Index=6
DHCPEnabled = False
Index = 6
InterfaceIndex = 8
IPEnabled = False
SettingID = {B1678277-03EA-4F2B-A6EC-896A32F1BE2A}
\\ZOULBURNER\root\cimv2:Win32_NetworkAdapterConfiguration.Index=7
DHCPEnabled = False
Index = 7
InterfaceIndex = 9
IPEnabled = False
SettingID = {2B4A48D8-C3E7-4C7B-9850-6B437F0A084A}
\\ZOULBURNER\root\cimv2:Win32_NetworkAdapterConfiguration.Index=8
DHCPEnabled = False
Index = 8
InterfaceIndex = 10
IPEnabled = False
SettingID = {8903518B-218A-40FA-A086-DDD9AFE64396}
ZOULBURNER
AdminPasswordStatus = 3
AutomaticManagedPagefile = False
AutomaticResetBootOption = True
AutomaticResetCapability = True
BootROMSupported = True
BootupState = Normal boot
Caption = ZOULBURNER
ChassisBootupState = 2
CurrentTimeZone = 60
DaylightInEffect = False
Description = AT/AT COMPATIBLE
Domain = WORKGROUP
DomainRole = 0
EnableDaylightSavingsTime = True
FrontPanelResetStatus = 3
HypervisorPresent = False
InfraredSupported = False
KeyboardPasswordStatus = 3
Manufacturer = Gigabyte Technology Co., Ltd.
Model = GA-990XA-UD3
Name = ZOULBURNER
NetworkServerModeEnabled = True
NumberOfLogicalProcessors = 8
NumberOfProcessors = 1
PartOfDomain = False
PauseAfterReset = -1
PCSystemType = 1
PCSystemTypeEx = 1
PowerOnPasswordStatus = 3
PowerState = 0
PowerSupplyState = 2
ResetCapability = 1
ResetCount = -1
ResetLimit = -1
Roles = LM_Workstation LM_Server NT Potential_Browser Master_Browser
Status = OK
SystemType = x64-based PC
ThermalState = 2
TotalPhysicalMemory = 17160171520
WakeUpType = 6
Workgroup = WORKGROUP
  1. Yes i have :-)
Thank you so much for helping. Best regards. Fredrik Sweden
See anything wrong? I am really interested in getting color tracking to work :-) my firmware on the Drone is 1.11.5 i have also tested 1.7.6 but no difference..
Looks like your PC is surely fast enough - my first thought was an error due to performance issue. It works on our PC's here for testing, so let me walk through a few things we can do to diagnose the issue...
i'd like you to configure the tracking speed to very slow half speed before connecting to the AR Drone. When you do this, does the camera last longer?
Ill try.. wait 5 min :-)
No..
It crashes in less than a minute.
I can give you access to my pc through teamviewer If you want to test something..? Just give me an email to send number and password to.
Actually, If I set the tracking speed to slowest it takes like 1 minute before it crashes.. and if set to fastest it takes like 30 seconds...
And if i use my ps3 eyetoy camera it doesn't crash at all... :-/
To clarify...
  • slider is all the way to the LEFT it crashes in 30 seconds?
  • slider is all the way to the RIGHT it crashes in 1 minute?
