Crashing While Using Ar Drone (1.0) Camera In ARC
Hey. Thanks for a great program, but i need some help.
I can control my AR DRONE 1.0 from the ARC. BUT, when i add camera controller component in the program it takes about 15-30 seconds, then the program crashes with the following error reports:
OS: Windows 8 64bit
- System
  - Provider
   [ Name]  Application Error
  - EventID 1000
   [ Qualifiers]  0
   Level 2
   Task 100
   Keywords 0x80000000000000
  - TimeCreated
   [ SystemTime]  2014-11-24T20:14:22.000000000Z
   EventRecordID 15106
   Channel Application
   Computer Zoulburner
   Security
- EventData
   ARC.exe
   2014.11.18.0
   546b9f48
   gdiplus.dll
   6.3.9600.17415
   54503bef
   c0000005
   000e9d85
   1bd0
   01d00822b25a65f7
   C:\Program Files (x86)\EZ-Robot Inc\EZ-Builder\EZ-Builder.exe
   C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.9600.17415_none_dad8722c5bcc2d8f\gdiplus.dll
   79e47332-7416-11e4-8312-50e549c467c1
This event is not displayed correctly because the underlying XML is not well formed. Below is the raw text of the event.
1026200x8000000000000015105ApplicationZoulburnerApplication: ARC.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.AccessViolationException Stack: at System.Drawing.SafeNativeMethods+Gdip.GdipDrawImageI(System.Runtime.InteropServices.HandleRef, System.Runtime.InteropServices.HandleRef, Int32, Int32) at System.Drawing.Graphics.DrawImage(System.Drawing.Image, Int32, Int32) at EZ_B.Camera.(System.Object) at System.Threading.ThreadHelper.ThreadStart_Context(System.Object) at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object) at System.Threading.ThreadHelper.ThreadStart(System.Object)
Anyone know what to do? Best regards. Fredrik Sweden
I tested again.
All the way to the left: ~1 minute then crash.
All the way to the right: still running after 10 minutes it seems now..
Hmm...
And now.. after 12 minutes it crashed with the slider all the way to the right.
okay, so the slider to the right takes longer to crash - interesting... let me take a look over here locally and see what I can find.
The video stream is decoded using the ffmpeg library - so the issue appears to be with the framerate specified through that library. I'll take a look and get back to you
Ok. Thanks. But i dont understand why it doesn't crash when i do the exact think but with the ps3 eye camera.. and when using that one i can have the slider all respekt way to the left and it still doesn't crash..
Well.. lets see it you find anything. :-)
The reason it does not crash when not using the AR Drone camera is the reason stated above - which I am investigating. The AR Drone uses the ffmpeg library for decoding the video stream. The AR Drone (only the ar drone) appears to have an issue with ffmpeg library. I am investigating:)
Believe I have solved this issue - however, I cannot be certain because I'm unable to reproduce it on our PC's. I will post an update for you to test in this thread later tonight.
#15
Yay!
You are the best..
Thanks! :-)
And later tonight is? cause it seems that you COME to work when i come HOME from mine ;-)
its 19:45 CET here in Sweden :-)
