Cognitive Sentiment icon Cognitive Sentiment — Detects positive sentiment percentage of input text using cognitive ML; returns $SentimentPercentage, shows face, graph, and status for analysis. Try it →
Crashing While Using Ar Drone (1.0) Camera In ARC
Hey. Thanks for a great program, but i need some help.
I can control my AR DRONE 1.0 from the ARC. BUT, when i add camera controller component in the program it takes about 15-30 seconds, then the program crashes with the following error reports:
OS: Windows 8 64bit
- System
  - Provider
   [ Name]  Application Error
  - EventID 1000
   [ Qualifiers]  0
   Level 2
   Task 100
   Keywords 0x80000000000000
  - TimeCreated
   [ SystemTime]  2014-11-24T20:14:22.000000000Z
   EventRecordID 15106
   Channel Application
   Computer Zoulburner
   Security
- EventData
   ARC.exe
   2014.11.18.0
   546b9f48
   gdiplus.dll
   6.3.9600.17415
   54503bef
   c0000005
   000e9d85
   1bd0
   01d00822b25a65f7
   C:\Program Files (x86)\EZ-Robot Inc\EZ-Builder\EZ-Builder.exe
   C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.9600.17415_none_dad8722c5bcc2d8f\gdiplus.dll
   79e47332-7416-11e4-8312-50e549c467c1
This event is not displayed correctly because the underlying XML is not well formed. Below is the raw text of the event.
1026200x8000000000000015105ApplicationZoulburnerApplication: ARC.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.AccessViolationException Stack: at System.Drawing.SafeNativeMethods+Gdip.GdipDrawImageI(System.Runtime.InteropServices.HandleRef, System.Runtime.InteropServices.HandleRef, Int32, Int32) at System.Drawing.Graphics.DrawImage(System.Drawing.Image, Int32, Int32) at EZ_B.Camera.(System.Object) at System.Threading.ThreadHelper.ThreadStart_Context(System.Object) at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object) at System.Threading.ThreadHelper.ThreadStart(System.Object)
Anyone know what to do? Best regards. Fredrik Sweden
#25
Yes. It seems that the program crashes earlier when i activate tracking.
#26
Okay, i'll continue to look into this.
#28
I Bought a laptop with windows 7 today and thought that would help.
Crashed in below 20 seconds. this is what the log looks like if it helps you.
.Net Runtime
Stack:
Application error
Faulting application name: ARC.exe, version: 2014.11.26.0, time stamp: 0x54760c70
Faulting module name: gdiplus.dll, version: 6.1.7600.16385, time stamp: 0x4a5bd976
Exception code: 0xc0000005
Fault offset: 0x000b31a0
Faulting process id: 0x3d8
Faulting application start time: 0x01d00b562f6b2cfc
Faulting application path: C:\Program Files (x86)\EZ-Robot Inc\ARC.ARC.exe
Faulting module path: C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7600.16385_none_72fc7cbf861225ca\gdiplus.dll
Report Id: e3261f51-7749-11e4-a43b-001641dcd097
#29
Not too strange it crashed almost instant with the laptop.
The ARC software i Downloaded today 2014-11-26 was set to highest (to the most left) in tracking speed by Default.
Moved the slider a bit to the right and it took atleast 3 minutes until it crashed again.
#30
This is really a strange situation - yesterday I was flying our AR Drone v2 around the office until the batteries died with zero problems. We have many people using the Drone v2 with ARC without issues as well - i'm struggling to understand what can be causing this...
The strack trace mentions a thread - which a cross-threading issue would be my first solution. However, the invoke is called on the object when required and tested successfully yesterday. The access violation tells me the object may be attempted to be referenced twice during threading - but I do not see how that can happen either.
There are no blocks of code missing exception handling throughout the entire video system - .Net is surely behaving different within your environment and I do not know why.
I will create another build for you that removes the threading. It will slow the camera and interface down considerably, but if it works that will identify the issue.
Have you created a project for this example? If so, will you share it with me? Use the ATTACH FILE button in this forum to include the project
#31
DJ, note that he is using a Drone 1, not a 2. Could something have broken when you added support for the 2?
#32
Oh! He's using a v1? How did i not see that - geez! I must be losing my mind, it even says v1 in the subject and it still didn't click:P
Okay, i have been diving into the v2 code and pulling my hair out. Looks like i need to take a look at the v1 code. I know the v1 works, but haven't spent any time testing toward this issue because I thought it was the v2.
