TCP Client icon TCP Client — Telnet-like ASCII TCP client for ARC: connect to IP:port, send ASCII, view raw or HEX server responses with local echo Try it →
Converting Script Code To Javascript
Can you convert the following Script code to Javascript?
controlCommand("Camera", "CameraFaceTrackingDisable") $FaceRecog = 0 $Speech = 0
Change eyes to blue
if (IsConnected(0) = 1) pwm(d17,100) pwm(d18,0) pwm(d19,0) pwm(d21,100) pwm(d22,0) pwm(d23,0) endif
Set all servos to start position
Servo(d0,90) Servo(d1,90) Servo(d2,40) Servo(d3,180) Servo(D4,25) Servo(D5,145) Servo(D6,90) Servo(D7,75) Servo(D8,140) # R Wrist Servo(D9,90) # L Wrist Servo(D10,90)
Pause for a tiny bit to ensure the servos have been initialized
sleep(100)
Set speed of these servos
ServoSpeed( D0, 5 ) ServoSpeed( D1, 5 ) ServoSpeed( D2, 5 ) ServoSpeed( D3, 5 ) ServoSpeed( D4, 5 ) ServoSpeed( D5, 5 ) ServoSpeed( D10, 5 )
if ($Topic = "") goto(section2) endif
Read random line from Topic File
$TopicFile = "c:\Images" $TopicFile = $TopicFile + GetCharAt($TopicFile,2) + GetCharAt($TopicFile,2) + $Topic + ".txt" $Text = FileReadLineRandom($TopicFile)
Speak specified text
#$Text = "Hello human. My name is pepper. I am here to help you."
:section2 ShowControl("Display Interface") sleep(200) sayWait($Topic) say($Text)
If no audio is played for over 2 seconds, then stop
$SilenceCnt = 0 repeatwhile($IsSpeaking) ServoRandom( D0, 40, 140 ) ServoRandom( D1, 75, 95 ) ServoRandom( D2, 40, 120 ) ServoRandom( D3, 100, 180 ) ServoRandom( D4, 30, 50 ) ServoRandom( D5, 130, 150 ) ServoRandom( D6, 100, 130 ) ServoRandom( D7, 45, 75 ) ServoRandom( D10, 80, 100 ) #Waist sleep(2000)
endrepeatwhile
#Change eyes back to green if (IsConnected(0)) PWM(D17,0) PWM(D18,0) PWM(D19,100) PWM(D21,0) PWM(D22,0) PWM(D23,100) endif $ScriptRunning = 0 $FaceRecog = 1 $Speech = 1 CloseControl("Display Interface") controlCommand("Speech Recognition", "PauseOff") controlCommand("Camera", "CameraFaceTrackingEnable") stop()
Script by Synthiam Inc.
Run JavaScript or Python scripts in ARCx to automate sequences, react to events, and control other skills via commands.
Certainly! Below is the converted JavaScript code for your ARC project. I've translated the EZ-Script commands to JavaScript, using the ARC JavaScript API.
// Disable camera face tracking
controlCommand("Camera", "CameraFaceTrackingDisable");
setVar("$FaceRecog", 0);
setVar("$Speech", 0);
// Change eyes to blue
if (EZB.isConnected(0)) {
    PWM.set(D17, 100);
    PWM.set(D18, 0);
    PWM.set(D19, 0);
    PWM.set(D21, 100);
    PWM.set(D22, 0);
    PWM.set(D23, 0);
// Set all servos to start position
Servo.setPosition(D0, 90);
Servo.setPosition(D1, 90);
Servo.setPosition(D2, 40);
Servo.setPosition(D3, 180);
Servo.setPosition(D4, 25);
Servo.setPosition(D5, 145);
Servo.setPosition(D6, 90);
Servo.setPosition(D7, 75);
Servo.setPosition(D8, 140); // R Wrist
Servo.setPosition(D9, 90);  // L Wrist
Servo.setPosition(D10, 90);
// Pause for a tiny bit to ensure the servos have been initialized
sleep(100);
// Set speed of these servos
Servo.setSpeed(D0, 5);
Servo.setSpeed(D1, 5);
Servo.setSpeed(D2, 5);
Servo.setSpeed(D3, 5);
Servo.setSpeed(D4, 5);
Servo.setSpeed(D5, 5);
Servo.setSpeed(D10, 5);
if (getVar("$Topic") === "") {
    gotoSection2();
// Read random line from Topic File
var topicFile = "c:\\Images";
topicFile += getCharAt(topicFile, 2) + getCharAt(topicFile, 2) + getVar("$Topic") + ".txt";
var text = File.readRandomLine(topicFile);
// Speak specified text
// var text = "Hello human. My name is pepper. I am here to help you.";
section2();
function section2() {
    showControl("Display Interface");
    sleep(200);
    Audio.sayWait(getVar("$Topic"));
    Audio.say(text);
    // If no audio is played for over 2 seconds, then stop
    var silenceCnt = 0;
    do {
        while (getVar("$IsSpeaking")) {
            Servo.setPositionRandom(D0, 40, 140);
            Servo.setPositionRandom(D1, 75, 95);
            Servo.setPositionRandom(D2, 40, 120);
            Servo.setPositionRandom(D3, 100, 180);
            Servo.setPositionRandom(D4, 30, 50);
            Servo.setPositionRandom(D5, 130, 150);
            Servo.setPositionRandom(D6, 100, 130);
            Servo.setPositionRandom(D7, 45, 75);
            Servo.setPositionRandom(D10, 80, 100); // Waist
            sleep(2000);
    } while (getVar("$IsSpeaking"));
    // Change eyes back to green
        PWM.set(D17, 0);
        PWM.set(D18, 0);
        PWM.set(D19, 100);
        PWM.set(D21, 0);
        PWM.set(D22, 0);
        PWM.set(D23, 100);
    setVar("$ScriptRunning", 0);
    setVar("$FaceRecog", 1);
    setVar("$Speech", 1);
    closeControl("Display Interface");
    controlCommand("Speech Recognition", "PauseOff");
    controlCommand("Camera", "CameraFaceTrackingEnable");
    Movement.stop();
Key Points:
  • Control Commands: Use controlCommand() to interact with other robot skills.
  • Servo and PWM: Use Servo.setPosition(), Servo.setSpeed(), and PWM.set() for servo and PWM control.
  • Variables: Use setVar() and getVar() for global variable management.
  • Loops and Conditions: JavaScript syntax is used for loops and conditions.
Feel free to ask if you have any questions or need further assistance!
