Midi Control icon Midi Control — MIDI I/O for ARC: send/receive notes, run per-note scripts, control PC or external instruments, with panic to stop stuck notes. Try it →
Resolved Resolved by Geoff!
Connecting To Ez-b In ARC.
Connecting To Ez-B In ARC.
I'm new to EZ and have built other projects, mainly Arduino based. I was finally able to add the device and update the firmware on com 6. When I try to connect to com 6 in the ARC the red led stays lit and after a few moments it goes back to blinking and the message "could not connect to the EZ-B" and offers to send me to a tutorial. Fresh batteries, windows 7 home, service pack 1. What to do confused Any and all help would be welcomed as I can't even get started.
I got the following diagnostic after I tried to connect "Received: Disconnected Connection Failed: System.Exception: Controller Not Responding at EZ_B.EZB.Connect(String hostname, String tcpPassword, Int32 baudRate) Disconnected" does that help? UncleMike
@Rich did that. also tried to reupdate the EZ-B OS fermware and the program reports "Attempting connection to COM6 EZ-B reports EZ-B Firmware V15.7 Connected Your EZ-B has the latest firmware. There is no need to update."
Sounds like your one or more batteries are low. Do you have a 5 volt -17 volt DC power adapter laying around? Something that can handle at least I amp
Hey,
I see that you said:
"EZ-B reports EZ-B Firmware V15.7"
With the current version of ARC the EZ-B Firmware should be V16. I see that you already said you installed the newest version of ARC, but let's try uninstalling everything first.
Then re-installing ARC, which should give you the newest EZ-B Firmware updater. After all that is done, try updating the firmware again and EZ-B should report EZ-B Firmware V16. After that try to connect the EZ-B in ARC. Let us know if this works out for you :)
I am now running EZ Board ver 2012.04.23.02 and now am connected to the board and starting to play with adding servos etc. New problem, I seem to have a bad modified servo as it wont run no matter which port i put it on will test it tomorrow on its own to see if there are bad joints at the plug. thanks for all the help guys, now on to bigger and better things. Will keep you all updated on my project a tank toy I am modifying for this. G'night all Unclemike
Originally an Arduino projecr now EZ-B
You should update the firmware to V16 and update ARC to the latest version.
If you upgrade to the latest version you will find that all servo ports need to be set again, surely it's better to upgrade before you add all of these controls?
Just download and install the latest release, run the EZ-B Firmware Update tool and follow the on screen instructions. Then run ARC and take advantage of the whole host of new features and functions it now offers from way back in April 2012.
Rich is completely right. The latest version will be your friend not the enemy
Get the all the latest greatest going and you will be in better shape. Be sure to keep us posted on the tank. That will be awesome!
#15
Marked "resolved" but it doesn't let me credit all the posters, so thanks Geoff, Ralph, Jstarne1 and Antron007. thanks for the help and warm welcome. UncleMike
