PCA9685 Servo Driver icon PCA9685 Servo Driver — Drive 16 servos over EZB I2C with a PCA9685 PWM controller, using ARC servo commands and hardware-timed outputs. Try it →
Compatible Ssc-32 Controllers
I was reviewing the threads discussing the use of a SSC-32 controller to add an additional 32 servo (analog) ports. My question is if there are any specific boards that builders have had success with other than the Lynxmotion? I am looking at the following board on eBay and was wondering if it would work with EZB v4/2? (Note that the description was poorly translated into English.)
            • DESCRIPTION - - - - - - -
Can be controlled using UART 32 road, the need to have a USB to TTL line, support SSC - 32 foreign software and control code, small volume, can drive high power steering gear (995996), can also cooperate with the arduino
MCU ATMEGA168 EEPROM = 24 lc256p CPU speed = 14.7456 M Serial port baud rate = TTL, 2400960 0,38.4 K, 115.2 K, 8 1 N Output = 32 road (servo or TTL) Input = 4 (static or atresia, analog or digital) Current requirements = 10 a (specific to provide their steering current) = 180 ° steering Angle Steering Angle resolution = 1 microsecond, 0.09 ° Steering gear speed resolution = 1 microseconds per second
I recommend two ezbs instead of this controller. You’ll find the data communication flooding by adding more ports to a single ezb with an expansion like this.
Anytime:)
Don’t get me wrong - some people have done that by using the ssc32 controller. I find it to be a little unstable as well.
For the price of a cheap knock off ssc32, you can always give it a shot!
I'll soon have three EZ-B 4's so it just makes better sense to go that route!
