Virtual Robot icon Virtual Robot — Display robot image with real-time servo position readouts and basic servo management including servo deletion Try it →
Command Syntax For Data Retrieval
It seems a lot of people are getting a little confused over the script commands for receiving data and have noticed the syntax is incorrect. So it's tutorial time again:)
Basically, the common mistake is to assume the command for receiving ADC, HTTP etc. data is like;
HTTPGet("https://192.168.0.100/temp.cgi";)
However that will return an invalid syntax.
If you think about it, that is no different to having a line of code which is;
23
The returned data in the HTTPGet example could be 23, so what use is 23 on it's own? You have to remember that all get/fetch commands should be looked at as though they are data and not commands. The data alone will be of no use if not used as part of a process or stored as a variable for later use.
The correct syntax would be;
$temp = HTTPGet("https://192.168.0.100/temp.cgi";)
or as part of a function
IF(HTTPGet("https://192.168.0.100/temp.cgi";) > 23)
  SayWait("Man, it's hot in here!")
ElseIf(HTTPGet("https://192.168.0.100/temp.cgi";) < 18)
  SayWait("Brrrr, it's cold in here!")
Else
  SayWait("It''s perfect in here")
EndIf
The same applies to all commands that will fetch data from somewhere including; GetPWM GetServo GetServoSpeed GetSpeed GetSpeedLeft GetSpeedRight GetCPUTemp GetVoltage GetADC GetRandom GetRandomUnique GetDigital GetPing HTTPGet GetChatAt GetByteAt GetByte GetAsByte GetBit GetVolume I2CRead UARTRead FileReadEnd FileReadChar FileReadLine FileReadAll FileReadLineRandom
And possibly more, I think I listed them all but with ARC updates so often it probably wont stay that way.
If you get a syntax error read the help on the right of the script dialogue, there are always examples:)
Update: That said, HTTPGet() will work without assigning variables etc. since it can be used to operate devices and websites etc. such as NotifyMyAndroid. However if used to return data it must be assigned to a variable or used as part of an operation/process.
Great compilation of commands that require that fetch data, I had no idea there were so many! ....I certainly stumbled on the I2CRead command earlier :( Thanks for this short but Sweet tutorial!
Yeah this one is short and sweet, I just wanted to explain that some commands need a little more to them than just the command on a single line. I plan to cover those commands a little better at some point however need some kind of script idea to follow where I can use them.
Some are V4 specific, the GetVoltage, GetCPUTemp and UARTRead, so until Six arrives I can only assume and get that part ready to test before it's posted. But the rest I'll cover with a bunch of examples shortly (in the mean time there are examples in ARC's examples folder).
I'd be interested in knowing what the new command UARTRead does and its applications but DJ was not "talking":)
Thanks Rich. And btw nice new profile pic.:)
