Relative Servos icon Relative Servos — Synchronize servos by designating a master; slave servos mirror scaled (decimal/negative) positions with min/max limits and pause control Try it →
ChatGPT Integration?
Chatgpt Integration?
I have been using ChatGPT a lot lately just to see what the AI can do.  I am impressed in many ways over previous Chatbot AI engines.   Integrating ChatGPT into ARC/Synthiam environment could lead to some very sentient like robot applications.   Is anyone working on a plug in for ChatGPT?
Hello DJ, I am back to pro status to try this skill out. I am having problems with this skill as it is not representive of Chat GPT 3 or 4 for that matter. The interactions are not similar. For instance I can tell Chat GPT to change its name and I cannot with this. The complexity of the answers are nowhere close. Am I missing something or have I misapplied the skill? Thanks!
When I asked the same question you did here is the answer I received
Human: i would like to build a robot with synthiam arc AI: Thank you for considering building a robot with Synthiam ARC. This software is designed to be user-friendly and easy to use, so you can create the robot of your dreams.
How did you get the response you did?
Edit the personality, perry. You have to tell jt what you want it to do.
chat gpt ui has their own personality description as well. Remember, chat gpt is just a web interface for gpt with a descriptor
Here’s a quick vid I made that shows how to change the personality
or you can be as vague as you want like the chat gpt ui does
Thanks for the response as always DJ! I will give it another try and see if I can do better.
Twitter
Daisy was an interesting choice.  IBM 7094 in 1961 programmed by John Kelly.
#15
DJ thanks for posting the video!
#16
I have been checking this out and when I ask the AI what year it is it response with ""2021".  When I ask it what day it is I get "Today is Wednesday August 8, 2017".   Is this normal to be so wrong?
I was hope it would be more like Alexa and I least no what day it was.
