Set Digital icon Set Digital — Toggle a digital I/O port between TTL low (0V) and high (3.3V/5V) in ARC; select board and port, simple on/off control-signal only. Try it →
Denmark
LinkedIn
Resolved Resolved by Nomad 6R!
Charger
Hi,
I am having great success with the Roli on the software side where I have integrated the EmguCV libraries with the SDK and doing a lot of experiments.
However, I got a sudden problem with the charger. The green light does not come on when attaching the charger to the Roli by with the charger cable hanging below its belly. I have always had this problem, but I the charger always managed to recognize the empty battery by carefully inserting the cable. My problem is now there constantly.
Could you assist ? Do I need a new charger ?
Sincerely
Jan
Denmark
LinkedIn
I don't know how to close this thread but nomad answered my question so the issue can be resolved
jop
you close this by checking who solved the problem.
Denmark
LinkedIn
Yes, but the menu suddenly disappeared. It must be an error on the web site.
Denmark
LinkedIn
I will close the thread when the menu appears again.
its enough that you check who solved the error for you. you can always talk further if you want. also its good to mention if you have a problem what kind off device, you use,post pics or video,that gives you better and faster respons.
Denmark
LinkedIn
Ok, then I think the issue is resolved. Thanks nomad.
Denmark
LinkedIn
#15
I just got the charger from the DHL carrier a few minutes ago, looks very good. The green light is on in a flick of a moment and the Rovi is charging.
I will continue my software project now. From making it see (done) to making it navigate ...
