Talk Servo V2 icon Talk Servo V2 — Animate servos to simulate jaw/mouth with ARC text-to-speech; configurable vowel/consonant timing, start sync, multi-servo control, pause/stop. Try it →
Denmark
LinkedIn
Resolved Resolved by Nomad 6R!
Charger
Hi,
I am having great success with the Roli on the software side where I have integrated the EmguCV libraries with the SDK and doing a lot of experiments.
However, I got a sudden problem with the charger. The green light does not come on when attaching the charger to the Roli by with the charger cable hanging below its belly. I have always had this problem, but I the charger always managed to recognize the empty battery by carefully inserting the cable. My problem is now there constantly.
Could you assist ? Do I need a new charger ?
Sincerely
Jan
jop
can you messure howmany volts you have when charging. use the contact form to ask for a replacement.
Denmark
LinkedIn
Hi nomad18.08,
thanks for help on this. I don't have a volt meter or any other measurement tools, so I have to use ad hoc methods. The charger does not get hot, so I don't think I am charging.
sincerely
Jan
jop
see that you can messure it and make a pic.send the pic along whit the contact form.you can also contact ez direct.
Denmark
LinkedIn
Thanks nomad,
Will a picture be enough of the charger connected with no green led glowing ?
I can buy a volt meter but it will cost me some, I am mostly a software guy.
/Jan
Denmark
LinkedIn
I have a picture of the situation with a Roli with empty battery and attached charger
Denmark
LinkedIn
Difficult to see because of the blitz, here is a closeup from an another angle
last pic will do
Denmark
LinkedIn
Cool, thanks. I hope to get a replacement so I can continue my programming.
