Command Duplicator icon Command Duplicator — Duplicate and synchronize commands from one master EZ-B to multiple slave EZ-Bs for simultaneous, mirrored robot actions. Try it →
Resolved Resolved by Proteus!
Changing The Name Of The Ez Network
Hi Guys.
Atm I have 9 EZ robots for teaching programming to kids. When they all get turned on more or less at once, there is 9 Networks pretty similar in name, this gives some confusion and irritation with both me and my students.
My question is: Is it possible to change the names of the Networks ? and if, how is it done ?
Thanks
That's not the same thing - a white board marker will wipe off with your fingers. It will work, but not last.
A Sharpie is a permanent marker - which I imagine Bic Brand has a similar version.
To remove it, simply spray White Board Cleaner on the area that was marked, and use a cloth to wipe it away. It will not come off with your fingers.
If you are unsure about the market - try it somewhere that will not be visible to ensure it comes off with white board cleaner spray:)
