Can't connect my Rolli to wifi it does not show up in network settings or in wifi signials stress
DAK
— Edited
4 Participants
Openai Dall-E Image
— Generate or edit images with OpenAI GPT Image from text or camera frames, with save and programmatic control commands.
I assure you the ARC Software has absolutely nothing to do with your WiFi network. Your Wifi network is managed by the Microsoft Windows Operating System and the respective drivers of your hardware. It would be much easier to diagnose if our software was responsible
Please reset your EZ-B with these instructions...
Following the reset, cycle the power on both your Computer and EZ-B
Cook the eggs and brings the OJ, I eat my words and complaints. Rolli works now. Thank you
The ez-b up to tricks again? I always reset the ez-b if I have a wifi issue. Usually it is the cause. Just a minor issue. Not a problem though.
I'd lean toward your wifi driver/network and Windows - this is because there is no gateway on the EZ-B. So on some machines, windows tends to say "let's ignore this network because it goes no where".
Glad to hear you're up and running
