Tic Tac Toe icon Tic Tac Toe — Play Tic Tac Toe with your ARC robot: configurable turn, win and draw scripts, cheat commands and optional speech-recognition control. Try it →
Can This EPS32 Work As An EZB?
Can the ESP32 work with Synthiam ARC, especially considering that the IoTiny is currently difficult to purchase?
For reference, here is the product link: Freenove ESP32-S3-WROOM on Amazon.
I'm interested in understanding if this specific ESP32 model can be integrated with ARC for robot programming and control, given the current availability issues with the IoTiny.
Esp32 by Espressif
Flash Synthiam ESP32 firmware to create a Wi-Fi EZB robot controller with ARCx for servos, sensors, scripting and web control
Servos Varies
UART Varies
ADC Varies
Digital Varies
#1   — Edited
Yes, the ESP32 DevKit v1 can indeed work as an EZB when programmed with the appropriate firmware. This allows it to interface with Synthiam ARC, enabling you to control sensors, servos, and other peripherals through the ARC software.
Factors to Consider When Using ESP32 with a Built-in Camera:
  1. Compatibility with ARC:
    • Ensure that the ESP32 is flashed with the correct firmware to function as an EZB. You can find the firmware and instructions on the Synthiam website here.
  2. Camera Resolution and Frame Rate:
    • Check the camera's resolution and frame rate to ensure it meets your project's requirements. Higher resolution and frame rate can provide better image quality but may require more processing power and bandwidth.
  3. Processing Capabilities:
    • Evaluate the ESP32's processing power to handle both the camera data and other tasks your project requires. The ESP32 is a powerful microcontroller, but complex image processing might require additional resources.
  4. Integration with Other Components:
    • Consider how the ESP32 will integrate with other components in your robotic setup. Ensure that it has enough GPIO pins and supports the necessary communication protocols for your sensors and actuators.
  5. WiFi Connectivity:
    • The ESP32 supports WiFi, which can be used for remote control and data streaming. Ensure that your network setup can accommodate the ESP32's connectivity needs.
  6. Power Requirements:
    • Check the power requirements of the ESP32 and the camera to ensure your power supply can support them without issues.
  7. Availability and Support:
    • As you mentioned, the ESP32 might be more readily available than other options like the IO Tiny. Consider the availability of support and community resources for troubleshooting and development.
By considering these factors, you can effectively integrate the ESP32 with a built-in camera into your robotic project using Synthiam ARC. If you have any more questions or need further assistance, feel free to ask!
Due to the significant amount of variants for ESP32 and Arduino-compatible controllers, it is impossible to confirm native compatibility. However, the current ESP32 Cam firmware is available here: https://synthiam.com/Support/Hardware/ESP32-Cam
It is designed to work with native ESP32 devices. Minor changes may only need to be made to make it work if it doesn't. Because there is no standard within open-source Arduino-compatible hardware, it is out of our control for what libraries or hardware configurations these products use.
It looks like Athena is confident that it will work.
