hi dj sir i just had a doubt ,can we use l293d for controlling motor using ez-b
karan413
India
— Edited
Shortcut Creator
— Shortcut Creator relocated to the ARC Options menu; new manual page provides updated Shortcut Creator documentation.
Have a read of this topic
It seems you can.
Hey @Karan413 , I used L293d motor driver... But had many issues with it.. It can't drive the motors for long times... It'll get heated up fast... Better to go for a L298n motor driver...
That would be due to the load of the motors, provided you are below the rated current that the L293d can handle it should be fine. If you are close, or over then upgrade to a heavier duty controller.
Yeah it was the load of the motors... I forgot to mention that... It would generally work out with the L298n Movement Panel though...
thanx
Don't forget to mark this as resolved if it has been
YA IT IS RESOLVED
