Rafiki Front Bumber icon Rafiki Front Bumber — Rafiki front bumper plugin: reads 4 proximity sensors via serial, updates ARC variables, blocks motor movement toward detected obstacles for SLAM Try it →
Hey @Karan413 , I used L293d motor driver... But had many issues with it.. It can't drive the motors for long times... It'll get heated up fast... Better to go for a L298n motor driver...
That would be due to the load of the motors, provided you are below the rated current that the L293d can handle it should be fine. If you are close, or over then upgrade to a heavier duty controller.
Yeah it was the load of the motors... I forgot to mention that... It would generally work out with the L298n Movement Panel though...
Don't forget to mark this as resolved if it has been:)
