Autonomous AI icon Autonomous AI — Autonomous AI robot skill with vision, speech, movement, animations, and self-directed multi-step tasks powered by LLMs. Try it →
Camera tracking glitch with all cameras
Camera Tracking Glitch With All Cameras
I noticed lately when I use the Camera, tracking only last "one" time, whether it is face, color or whatever.
How can I deleted the camera and re-install it?
EzAng
Hmmm I haven't been experiencing this. What seems to happen? With any tracking type once the object is detected the camera skill crashes?
I don't think you need to uninstall the camera. Is it a camera that you have just installed or have you been using it for a while? I'm just trying to determine if anything has changed with your setup.
Do you have the latest version of ARC installed?
I have the latest version of ARC - later I can try another camera
I tried my computer camera and Ez B Camera thanks
EzAng
So Jeremie, I just got back, what should I do?
EzAng
If you could answer the first few questions I had in my first post that’d help me out:D
I need more info on what’s happening actually happening.
#5   — Edited
Wish we can speck, I will try the JD robot next.
ok, when I use the EZ-B v4 Camera, tracking,   with an IoTiny
it only tracks once, then all the tracking boxes are empty - look below, I had it on face, then color, same thing happens, this just started.
I use DJ code:
here is the debug info: 2020/09/03 16:00:27 -05:00 - Attempting connection on 192.168.1.12:23 2020/09/03 16:00:27 -05:00 - Connected to 192.168.1.12:23 2020/09/03 16:00:27 -05:00 - Reports EZB v4 OS IoTiny 2020/09/03 16:00:27 -05:00 - Firmware 'EZ-Robot IoTiny standard firmware' on 'EZ-Robot EZ-B IoTiny' supports the following capabilities:
  • ADC with 12 bit Resolution
  • Can stream Audio v4 codec
  • Reports battery voltage
  • Reports CPU temperature
  • Read/Write Digital I/O Ports
  • I2C Master
  • LIPO battery protection & shutdown
  • PWM Duty on digital ports
  • PWM servos on digital ports
  • PWM servos on digital ports can release their position
  • Servo speed for PWM servos on digital ports
  • Has NVRam configuration and can be restored to default settings
  • Transmit Uart TX on all digital ports
  • Adjustable I2C clock speed
  • Ultrasonic Ping distance sensor support
  • 12 Byte Unique Identifier
  • Can stream video v4 codec
  • Native WiFi Connectivity from ARC
  • Broadcasts to ARC's PnP network scanner
Broadcasts to ARC's PnP network scanner 2020/09/03 16:00:27 -05:00 - EZ-Robot IoTiny standard firmware ID: 222-222-222-222-222-222-222-222-222-222-222-222 2020/09/03 16:00:27 -05:00 - Setting battery monitor voltage: 7 2020/09/03 16:00:27 -05:00 - Setting battery protection: True 2020/09/03 16:00:27 -05:00 - Setting i2c rate: 100000 2020/09/03 16:00:27 -05:00 - EZ-B voltage is 8.211534684 2020/09/03 16:00:27 -05:00 - EZ-B temperature is 25.02440624839843800C 2020/09/03 16:00:27 -05:00 - Connected 2020/09/03 16:00:36 -05:00 - Camera Initialized: EZB://192.168.1.12:24 @ 320x240
I downloaded ARC again, did repair, no luck
Like I said,  I will try the JD robot next., Tested JD robot, same thing happens,
I deleted Arc, fresh install - same thing
any ideas?
thanks EzAng
#6   — Edited
@Ezang:
this:
translates to:
// Wait until the camera detects a face
controlCommand("Camera", "CameraMovementTrackDisable");
controlCommand("Camera", "CameraUseTrackingScripts", false);
controlCommand("Camera", "CameraFaceTracking");
while (getVar("$CameraIsTracking") == 0);
controlCommand("Camera", "CameraDisableTracking");
controlCommand("Camera", "CameraUseTrackingScripts", true);
Audio.sayWait("I see a Face");
Basically WaitForFace blocky enables the cameraFaceTracking and then disables cameraFaceTracking
you can store the previous state i.e. before the WaitForFace and then set after the block
I believe is a design choice.
#7   — Edited
I assumed CameraTrackingType was the configuration setting but is not. So I believe the solution is to have a global variable to set/store the tracking state and then restore the state after the WaitForFace.
#8   — Edited
I tried it, no luck
EzAng
