Cognitive Vision icon Cognitive Vision — Microsoft Cognitive Vision integration for ARC: real-time object, face, emotion detection, OCR, confidence data and script-triggered robot actions. Try it →
Camera Train New Object Learn Area Size
When training a new object the learn area size (red rectangle) is always 80 x 80. I've tried different resolutions and the rectangle size does not increase.
  1. Is there away to increase the learn area size ?
  2. When i finish the learning process generates an error:
Quote:
Error Camera.SetCaptureImage: System.ObjectDisposedException: Cannot access a disposed object. Object name: 'Panel'. at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous) at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args) at System.Windows.Forms.Control.Invoke(Delegate method) at EZ_B.Camera.wAT7kMACFt(Object ) Camera Disabled
You cannot change the size
Your panel is still trying to be used when it's disposed. If you post your code I can assist further
I have no code, it's a new project: add Camera Object and start tracking
can you elaborate? Is this sdk or ARC or plugin?
If this is ARC, can you provide the steps that lead to this error?
open ARC new project add controls > camera Video Device> Select USB Camera Start Button Object Tab> Train new Object Press top corner Name of Object: Test1 Learn Selected *** wait *** Done Button
Strange - and that happens for you every time?
What USB camera make/model is it? Built-in laptop? Or external?
Not entirely sure if this will fix it because i am unable to recreate it. Give it a shot: https://synthiam.com/Community/Questions/9340
Also, i should note on the "object size" question:
Quote:
For best results, consider that you are teaching the robot specific details of the object, not the object itself. This means the entire object does not need to be in the training square. Only details which are unique to that object need to be in the training square. For example, you may not wish to teach the robot a can of soda/cola by putting the entire can in the square. Merely put the logo in the square, or any other identifying features.
