Speech Script icon Speech Script — Run custom scripts when speech starts/ends to sync servos and LEDs to spoken $SpeechTxt, with loop support, stop button and logs. Try it →
X-bee / Ez-b / Router
X-Bee / Ez-B / Router
Hi, I understand it is possible to replace the Bluetooth card with the X-Bee wifi card. Would it then be possible to connect the X-Bee to the router and initiate connection to the EZ-B via the router or would I have to directly connect to the X-Bee via the computer. (In my case also meaning disconnecting from the router)
Not sure on the X-Bee wifi card specifically but other ones used connect to the router and in ARC you point it to the Wifi card (or via a virtual com port) in the connection control.
Thanks, that is good news. Which other ones are you talking about? Could you provide a specific one that easily integrates with the EZB and performs the above?
Now class 1 Bluetooth UART modules are available and direct swap for the existing class 2 unit on the Ezb (rated at 30 ft). You could continue to use it with a direct connection through a class one USB dongle and they have a 300 ft range. No routers and no fiddling with IP addresses and such.
Both of those devices are class 2 and will only work for about 30 feet (on a good day). You will want a Class 1 Bluetooth device like THIS CLASS 1 that will work up to 300 feet.
Also when installing a class 1 bluetooth device to the EZ-Board you should also install a class 1 bluetooth dongle in your computer. You can search ebay and Amazon.com for choices of class 1 USB Bluetooth dongles.
Here's a class 1 dongle I have
