Servo Recorder icon Servo Recorder — Record and replay named servo movements with adjustable speed/direction (-5 to +5), multiple recordings, ControlCommand triggers and status var Try it →
Camera Overlay not reading JS variable
Camera Overlay Not Reading JS Variable
I’m building a simple pan camera rig on an EZ-B IoTiny (WiFi) with a single MG996R on D0, plus Camera Device for video. I want the Camera Variable Overlay skill to show a horizontal bar that tracks the pan angle. I selected the sample barScale1 image pack in Camera Variable Overlay, set X/Y/Width/Height to fit the lower third of the frame, named the control variable panAngle, set min=0 and max=180, ran Auto Assign, started the camera, then pressed Overlay. The images show up, but they don’t change when I move the servo if I update the value from a JavaScript control.
Initially I was assigning from JS like this (smoothing then rounding):
panAngle = Math.round((0.8 * panAngle) + (0.2 * newReading));
No response from the overlay. If I manually set an EZ-Script variable in a script like: $panAngle = 90, the overlay updates immediately. I changed my JS to use setVar and it started to work, but it’s jittery and occasionally displays the wrong image interval at the boundaries:
setVar("$panAngle", Math.round((0.8 * getVar("$panAngle")) + (0.2 * newReading)));
Questions:
  • Does Camera Variable Overlay only read EZ-Script variables prefixed with $, and does it require integers only (no floats)?
  • Is there a recommended update rate so the overlay doesn’t flicker when the value hovers on boundaries after Auto Assign?
  • When I change Camera Device resolution, the overlay shifts; are the X/Y/Width/Height in pixels tied to the active camera resolution, and is there a way to keep a fixed relative position across resolutions?
What is the correct way to feed a smoothed integer variable from JavaScript to Camera Variable Overlay and keep the overlay locked to the same pixel position when the Camera Device resolution changes?
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
Camera Device by Synthiam
Use PC or robot cameras for vision tracking: color, QR, glyph, face, object, motion; record video/data, control servos and movement, run scripts
Text Overlay by Synthiam
Overlay a variable on a processed camera image at X/Y coordinates; name the variable and attach to a specific or any available camera
Yes - the Camera Variable Overlay is expecting an ARC global variable, not a private JavaScript variable.
What’s happening
In ARC:
  • panAngle = ... creates a local JS variable
  • setVar("$panAngle", ...) creates/updates an ARC global variable
  • the overlay skill reads the global variable, so your first version had nothing to read
So this part is the correct approach:
setVar("$panAngle", Math.round((0.8 * getVar("$panAngle", 90)) + (0.2 * newReading)));
Answers to your questions
1) Does Camera Variable Overlay only read $ variables?
Yes. Use a global variable with $.
It also does not care that the value came from JavaScript or Python - it only cares that the value exists in ARC’s global variable manager.
2) Does it require integers only?
For the overlay’s bar-style image selection, use integers.
If you feed decimals, ARC will still store the value, but the image interval selection can become unstable near thresholds. So the best practice is:
  • smooth with floating point if you want
  • round once right before setVar()
  • keep the variable as an integer
3) Why does it flicker at boundaries?
That’s normal if the value sits right on the edge between image slots. Two fixes:
  • add hysteresis / deadband
  • or snap to steps before publishing to the overlay
For example, if the bar pack has 19 images, don’t publish every single degree. Publish in chunks.
Example:
var current = getVar("$panAngle", 90);
var smoothed = (0.8 * current) + (0.2 * newReading);
var snapped = Math.round(smoothed / 5) * 5; // snap to 5-degree steps
setVar("$panAngle", snapped);
That will reduce flicker a lot.
Use a global variable as the shared value, and update it at a steady rate:
setVar("$panAngle", Math.round(smoothed));
If you’re updating very fast, try publishing at around 10-20 Hz instead of every tiny sensor change. That’s usually enough for a UI overlay and looks smoother.
About resolution shifts
Yes - the X/Y/Width/Height settings are pixel-based for the active camera resolution.
So if you change camera resolution, the overlay position can shift because those coordinates are tied to the current frame size.
Best practice
If you want the overlay to stay in the same relative place across resolutions, compute the overlay rectangle as a percentage of the frame size, then convert to pixels when the camera starts.
For example:
  • x = 10% of width
  • y = 80% of height
  • w = 80% of width
  • h = 15% of height
You can do this with a script when the camera starts, using the camera resolution variables.
Example JavaScript:
var w = getVar("$CameraResolutionWidth", 320);
var h = getVar("$CameraResolutionHeight", 240);
var x = Math.round(w * 0.10);
var y = Math.round(h * 0.75);
var overlayW = Math.round(w * 0.80);
var overlayH = Math.round(h * 0.15);
setVar("$overlayX", x);
setVar("$overlayY", y);
setVar("$overlayW", overlayW);
setVar("$overlayH", overlayH);
Then use those values in the overlay skill if it supports variable-driven placement. If not, you’ll need to reset the overlay dimensions when you change camera resolution.
Important note
If your goal is just to show the pan position, a Text Overlay or a custom overlay skill may sometimes be more flexible than a bar image pack. But if you want the bar graphics, what you’re doing is fine - just use global variables and quantize the value.
One more suggestion
Because you’re using an IoTiny, remember the overlay is running in ARC on the computer, while the servo is on the board. If you want a clean architecture, it’s often better to let the servo position itself be the source of truth and mirror that into $panAngle whenever you command the servo.
For example:
var pan = Math.round(newReading);
Servo.setPosition(d0, pan);
setVar("$panAngle", pan);
That way the overlay always follows the commanded angle.
Quick checklist
  • Use setVar("$panAngle", value) - not a plain JS variable
  • Keep the value integer
  • Smooth first, then round
  • Add snapping/deadband if the image flickers
  • Recalculate overlay position when camera resolution changes
Relevant docs
If you want, I can show you a clean JavaScript script for the IoTiny pan servo that:
  1. smooths the angle,
  2. clamps it to 0-180,
  3. updates $panAngle, and
  4. avoids overlay flicker.
Also, what’s your bigger goal here - just a visual pan indicator, or are you planning to have the camera track a target and drive the servo automatically?
