PCA9685 Servo Driver icon PCA9685 Servo Driver — Drive 16 servos over EZB I2C with a PCA9685 PWM controller, using ARC servo commands and hardware-timed outputs. Try it →
I loaded the latest version of ARC and now the program runs slow. If I put the camera on pause everything is as usual however with the camera on, it takes between 2 and 4 seconds for the program to respond to any mouse click. I tried deleting the control and puting in a new one. No help.
@Bookmaker that is due to the processor speed of your computer. Auto is very slow on slower machines. There is soooooooo much processing in Auto mode, you have no idea. It's scanning for motion, color, glyph (if enabled), and faces. So you can imagine the processing being 4 times more than tracking a single mode.
For vision tracking, you can now see why using a computer is necessary:)
What are the specs of your computer?
6 GB Ram, Intel i5 2300 CPU @ 2.80 Ghz, 64 bit , 1000 GB Hard Drive
DJ, Now my voice activation is going off when no command is given. I tried de-sensitizing it but that did no good. Ever heard of this before?
Sounds like your windows might have some conflicting utility or virus scanner or something installed. Thousands of installations without similar issues. You can make your phrases longer than just one or two words, that will help.
Your machine is very powerful and should be able to handle auto vision detection. We test on a fast machine and a slow machine.
