Wondering how DJ got the Brookstone rover to follow the ball in the Brookstone video. Must be a script? thanks JW
— Edited
HTTP Server
— Remote web control of ARC desktop: live screen interaction, movement control, camera list, EZ-Script/ControlCommand console with remote execution.
i didn try it myself dont have ez-b yet. [url=]roover
He did it without the EZ-B just using the Brookstone rover and ARC software.
yes whit the keys up/down/left or right
open ARC choose open project choose legacy double click and choose roover. on all the you see this key ? there you find the answers
Nope nomad18.08 I'm looking for the tracking to set the movement panel. I want the Brookstone rover to follow the ball by moving the robot.
Open ARC
Select Project Tab from Menu Ribbon
Select Add Control
Select Robots
Choose Brookstone Rover Movement Panel
Now we will add the camera...
Press Add Control
Select Camera
Select Camera Contorl
Choose the Brookstone Rover from the drop down
Press the GEAR CONFIG button on the camera control
Select "Enable Movement Tracking" checkbox (ensure move forward is also checked)
Press SAVE on the config menu
Select TRACKING tab on the Camera Control
Press the COLOR checkbox
Select the COLOR tab on the Camera Control
Choose your color, and use the slider to adjust the brightness of the object
If you wish to define your own color, use the Multi Color Tracking Option. And you can configure multi colors on the Multi Color Tab of the Camera Control
Doesn't get any easier than that
PS, every control has a ? next to the X button. Press the ? to bring you to a help page for that control. For example, press the ? button on the Camera Control and you will be brought to tutorial videos which explains how to use it.
Also, almost every option in ARC has blue question marks next to them. If you click or hover on the option, you will be presented with help.
We couldn't possibly make it any easier
ww321 can you post a pic when you found all.thnx good explanation dj
Can't find the GEAR CONFIG button ? Humm Maybe I'm blind or need more functioning brain cells? LOL
